Question about Onkyo TX-SR601 Receiver
Onkyo tx sr 601 cannot store the memory settings after i turn it off. what do i do in order to retain it into the memory?
SOURCE: Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Posted on Jun 02, 2008
SOURCE: My Onkyo Receiver TX 601 is turning itself off
May not help, but I had the same thing when I turned up the volume.. off it went.. then I found my two surround sound speakers had the wires shorting. Looks like a safety switch if there is a problem. Could check if the wires are crossed, shorted, and/or thick enouch to handle the volume.. test it by just having the stereo speakers enabled. Cheers,
Posted on Jul 30, 2008
  • 16 Answers
SOURCE: Onkyo TX-SR 606 KEEPS CLICKING INSTEAD OF TURNING ON WHEN POWERED
Here are your options:
1. An electrical problem, where your receiver has a grounding problem.
2. Your speaker wire connections are actually touching each other and that's why your receiver is not turning on.
Posted on Nov 15, 2008
hi-fi
  • 25 Answers
Adjust bass control to half position then feed loud signal,if it shut off adjust the bass contol to zero position,if it shut off again the defect is in the over load protection circuit it is already sensetive to loud signal.you may call the nearest audio amplifier technician on you.
Hope it may help you,
Posted on Dec 29, 2008
  • 4234 Answers
SOURCE: i have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
Posted on Nov 04, 2009
Channel memory does not work
I have the Onkyo TX-SV 444 and i had the same problem.I fixed it by replacing the super capacitor (C701) .047F 5.5V in the front board.1_13_2013_5_28_41_pm.jpg
Jan 10, 2013 | Onkyo TX-SR606 Receiver
Hi there, I have been experiencing problems with my Onkyo TX-SR 703e receiver. Lately, the volume from my right font speaker appears to be lower than usual. i.e. as if there is something blocking the...
Manual is here
http://www.intl.onkyo.com/downloads/manuals/pdf/tx-sr803_703_manual_e.pdf
Assuming you are in the USA
ONKYO U.S.A. CORPORATION 18 Park Way, Upper Saddle River, N.J. 07458, U.S.A. Tel: 201-785-2600 Fax: 201-785-2650 http://www.us.onkyo.com/
probably a bad capacitor
Look here
https://www.badcaps.net/index.php
Nov 07, 2017 | Onkyo TX-SR703 Receiver
I have SR 307 onkyo A/V receiver home theatre system. the remote control has stopped working. i checked with a local dealer and that the remote is okay and something has wrong in the receiver,
Did you check the remote with another Onkyo system at the dealer ??. If its OK try resetting the system. Remember you will loose all your stored presets ( FM and customized settings ) and the Amp will go back to factory settings.
While in standby mode hold down the DVD button and press the Standby/On button., the display will show Clear and the Receiver will go into standby mode. Turn it on and try the remote once again.
Jun 01, 2011 | Onkyo TX-SR307 A/V Receiver
Onkyo TX-DS777 does not retain settings after power loss
No internal battery, a large "SuperCap" on the main board acts as one. Look for C8007, 0.1 F, 5.5V.
Apr 26, 2010 | Onkyo TX-DS777
Onkyo TX-DS898 Memory Loss
THEY USE A MEMORY CAP.ITS LOCATED ON THE MAIN PCB ASSEMBLY, REF. C7701 ONKYO PART NUMBER IS 3000078/ WITH THE UNIT TURNED OFF MEASURE THE VOLTAGE YOU SHOULD HAVE APPROX 5V IF NOT THE CAP IS BAD. ALSO MEASURE WITH UNIT ON AND YOU SHOULD ALSO MEASURE 5 V IF NOT THEN THE SUPPLY VOLTAGE GOING TO THE CAP IS BAD.
Apr 18, 2010 | Onkyo TX-DS898 Receiver
Nov 09, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-28 Reciever memory function not working
Replace super capacitor in the front board (C712) with part # 598-EDLF473A5R5C .47F 5.5V form Mouser Electronics. I did. It worked.
Aug 13, 2008 | Denon DRA-395 Receiver
Onkyo TX-SV414Pro
setting the stations goes like this:
First hit class a, b, c etc, and to clear out what is there, hit 1, then hit both memory and the one next to it at the same time to delete what is in there, To program, hit memory, then quickly, class a, b, c, etc. What it does it store that station in the NEXT AVAILABLE slot, so it is best to clear all slots, and have the station call numbers ready in the order you wish to set them.
Jun 15, 2008 | Onkyo TX-SV414Pro Receiver
Jun 01, 2008 | Onkyo TX-SR702 Receiver
Onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
Feb 03, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR601 Receiver Logo
133 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
