Question about Braun WK210 AquaExpress Cordless Electric Kettle
Braun wk210 switch - Braun WK210 AquaExpress Cordless Electric Kettle
I have a Braun 7680, and the switch won't work - it is stuck on "on".
Most likely, the mechanism is broken and will need replaced. The switch is part of the trimmer assembly which comes attached to the outer casing. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-body-housing-select-models-p-811.html
You will also find disassembly tutorial at the link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
Nov 17, 2010 | Braun 360° Complete 8985 Electric Shaver
Where to get and how to replace the shaver switch on 7680?
The switch is part of the outer case and can be found at shaveroutlet.com. See link below
To replace, you will need to gently pry off the cap that surrounds the cord hle on the bottom. Once removed, the side grips will pull away easily revealing 4 screws on the back. Remove screws to take the bask of case off and then lift out the 'guts'. Reassemble in reverse order
Sep 30, 2010 | Braun Syncro 7680 Electric Shaver
Braun 7680 won't shut off
Every time I have seen this problem, the switch apparatus was broken and had to be replaced. The switch/trimmer assembly comes with the case and can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-syncro-body-housing-select-models-p-811.html
Apr 10, 2010 | Braun Health & Beauty
Braun Tassimo - plug it in and no lights
have you switched it on on the back of the tassimo
Jan 13, 2010 | Braun Tassimo Espresso Machine/Coffee...
Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
Jan 07, 2010 | Braun Health & Beauty
Clock works but on button does not. Help! I need my coffee! this is for my Braun Aromaster KF 12.
I would take it apart and verify if the switch works with a DMM (multimeter) on the ohms(resistance) setting.
if the switch is bad then replace it.
if the switch tests ok then keep searching until you find the problem.
if a major part is broken you might want to buy another at a thrift store or yard sale and keep the broken one for spare parts.
Dec 29, 2009 | Braun Aromaster KF 12 Coffee Maker
Braun KF400 Aromaster 10-Cup Coffeemaker
try cleaning the switch, if that does not work then replace the switch.
Dec 06, 2009 | Braun Aromaster KF 400 Coffee Maker
Where I can get a replacement backplate for my Braun M880 mixer?
Braun Products & Replacement PartsPayPal Braun Shaver, Appliance & Dental Parts. Parts Ship Free over $60. SmallAppliance.com
Good Luck_Ned_
Nov 05, 2009 | Braun M880 MultiMix Hand Mixer
Broken switch
You can email Customer Service at Braun www.braun.com, give them you model number, and see if they will sell you a switch, but these unit's are made to be throwaway.
I just looked at the unit at Braun's website, and they don't show any replacement parts except for having to do with the caraffe.
I know, it's hard to let go of a perfectly good coffee maker like this, but, it's how the world has become.
Jan 22, 2009 | Braun Coffee Makers & Espresso Machines
Braun WK210 AquaExpress Cordless Electric Kettle Logo
Top Braun Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
