Question about Zanussi 24 in. DE6744S Free-standing Dishwasher
Will not start - Seems to be stuck on Half Load & Economy Cycle
The dishwasher won't start today! I loaded it, switched it on but it is stuck on the previous setting from a few days ago of Half Load & Economy Cycle. On the far right hand side of the control panel there is a flashing light next to the 2nd icon down but as I do not have the manual I am not too sure what this is but it is 3 vertical lines with one horizontal line underneath. Does anyone have any suggestions? I have swtiched the dishwasher off at the wall but when I plug it back in the problem is still there. I've also taken half of the dishes\plates out in case it was too packed but this hasnt made any difference. Thanks for any help
  • 641 Answers
Try to unplug the power cable for few houres and then plug it again. It mighet reset the control unit. Good luck !
Posted on Jul 24, 2007
SOURCE:
My Whirlpool washer #W10251314 Will fill to required level,Locks,Wait a few seconds,Attempt washing and then sounds as something trip.Will keep doing this.
Try washing a half load to see if it will actually work, if it does then you may have a load sensor problem. Are any economy switches on, like half load or other types ? Set all switches to 'max' so to speak and try a half load wash also try a different program cycle (but try with a few old towels and sheets, don't want to risk any good stuff)...... Red.
Dec 03, 2014 | Whirlpool Washing Machines
Dishwasher not running through entire wash cycle
If I understand right, you saying no/little water is entering the washer?
First, look for the float switch valve.
Here's an example of what you're looking for:
http://appliancejunk.com/forums/gallery/1_12_08_07_8_34_08.jpg
It's the item in the lower right, with the spoon stuck under it.
If this float is stuck/hung-up in the UP position, it won't allow water to flow, as it senses that the water level is already at maximum.
Try to lift yours and see if it freely drops back down on it's own.
Sometimes they get gummed up and stick, or get pulled up and tilted a little, or have something (like a spoon) stuck under them.
Nov 21, 2013 | Asko 24 in. 1585 Built-in Dishwasher
Maytag dishwasher starts too easily and gets stuck in wash cycle
see this causes and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Sep 28, 2012 | Maytag MDB7100AWB Dishwasher
Unit comes on but seems to be stuck on drain cycle. Have had unplugged for day and tried to start a load and still sounds like its trying to drain, door won't lock, and unit won't shut off...
Good evening
Have you had a look at the manual?
Could a fuse in the machinery have blown?
seems to me that here is something to do with the electronics that is not functioning as it should.
Kolbrun
Feb 26, 2012 | Whirlpool Washing Machines
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
The normal and economy lights are blinking and cannot get to wash through a full cycle. water is in the bottom of the washer
You will have to check if the dishwasher is stuck in the drain cycle or wash cycle.
The normal and economy lights flashing means there is flooding in the unit.
Reset the unit by pressing START button for 4 secs. If the flashing does not stop then you have to call the technician. There may be a leakage which is causing the flood switch to activate.
May 21, 2011 | Viking 24 in. Professional Series VUD040...
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Takes two and a half hours to run a load of dishes
They probably aren't running the hot water at the sink before starting the dishwasher. You know how it takes time to get hot water at the tap when you turn it on? well the new dishwashers use such little water, that they will fill with cold/warm water, and try to heat it up to 170+ degrees before continuing the cycle
Apr 04, 2010 | Dishwashers
Zanussi 24 in. DE6744S Free-standing Dishwasher Logo
309 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
