Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Paper Jam I have a paper jam where do I realse the tension to get it out? My printer is a Kodak ESP5?
  • dcpink Jan 27, 2009
    Please tell me how to unjam my printer.
  • Anonymous Mar 26, 2009
    the esp5 took in at least 10 sheets of photo paper and jammed. You can not pull the pages out....we've even tried to pull the paper with pliers.
    Sergeant:
  • Kodak Expert
  • 285 Answers
On the back release the cover and pull it out. you cant release the tension.
Posted on Jan 28, 2009
How do you open the rear door to fix a paper jam on a Kodak 5250 printer?
There are two plastic tips that you pinch inward at the lower back of the printer. A rectangular plastic piece will come out if you give it a god tug and you should be able to remove any jammed paper. I took mine off and never put it back on because it is aggravating to remove. I also had a problem of every 5-6 sheets of paper would not feed correctly through the printer and a paper jam notice would be displayed. I have all but remedied this too by stretching two heavy duty rubber band around the paper dispensing tray close to the bottom to provide more tension on the paper feeder itself. WORKS GREAT FOR ME! GOOD LUCK! Mine is a Kodak esp 3.2 but it paper jams a lot so maybe this will help you some as well?
Aug 09, 2014 | Kodak ESP Office Equipment & Supplies
My kodak All-in-one printer ESP9 goes instantly in paper jam. Checked for a paper jam and found no paper jam or any paper anywhere inside machine. Pressed down on "OK" button and printer...
Had same issue with my ESP 9, called up the kodak support lines and spoke to them over the phone, getting a replacement sent out free of charge and I've owned this for 1 year and 4 months and only had one prior printer jam which righted itself in the past. Seems like ESP 9's are prone to the unfixable printer jam.
Best bet call kodak and get it sorted.
Jan 12, 2011 | Kodak Office Equipment & Supplies
Printer paper is jammed. Is there a release?
is there a... what? you didnt provide additional information, and you left the question unfinished. is there a way to remove the paper? is there a solution? yes. the paper can be removed. but i dont have enough information.
Product summary The good: Improved photo quality over previous model; attractive design; large 3-inch LCD screen; easy-to-use Home Center software.
The bad: Poor quality build with several mechanical errors; average print speed; graphics quality still lacks definition.
The bottom line: The Kodak ESP5 is an attractive full color all-in-one printer, scanner, and copier, and casual photo enthusiasts will be happy with the watered-down editing software, but hard-core users should look elsewhere for a multifunction printer. The ESP5 is too expensive and suffers from too many mechanical deficiencies for us to give it our CNET stamp of approval.
you will continue to have these paper jams.
Jun 04, 2010 | Kodak ESP 5 Printer
How to fix paper jam in kokdak esp5 printer
www.kodak.com/go/itg
Select all-in-one printer
Select paper jam and follow the steps
Jan 15, 2010 | Kodak ESP 5 Printer
I have a ESP5 printer. There is an error message that says I have a paper jam, but I cannot find any paper.
A Piece of Paper may be in there. Find out it by replacing Catridge. Off the printer switch, See inside, out the paper from tray. Then keep it one by one.On Printer
Dec 10, 2009 | Kodak ESP 5 Printer
How do I clear a piece of paper jammed in my Kodak ESP5 All in one printer
1 Lift the output tray.
2 Open the paper trays and remove any paper.
3 Turn OFF your printer.
4 Wait 30 seconds, and then disconnect the following from the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
CAUTION: Do not use force when removing the paper from the printer.
5 Check inside the cleanout area for a paper jam. If necessary, remove any paper or debris.
6 If paper is not visible, check the printer for foreign objects, such as paper clips or staples. If necessary, carefully remove the foreign objects from your printer.
7 Open the printer access door.
8 Remove any foreign objects from the printhead access area, and then close the printer access door.
9 Connect the following to the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
10 Wait 30 seconds, and then turn ON the printer.
11 Squeeze and move the paper-width guide on the paper tray to the left.
12 Load the paper into the upper paper tray.
13 Squeeze and move the paper-width guide to the right until it touches the paper.
14 Close the paper tray.
Best of Luck
saj
Nov 02, 2009 | Kodak ESP 5 Printer
Paper Jam
Refer to www.kodak.com/go/itg and select all in one printers and then paper-jam . it will step by step show you on how to remove the paper-jam. if the printer does not work,after those steps Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost.
Jun 28, 2009 | Kodak ESP 5 Printer
Kodak ESP5 Printer - actual paper jam
you can pull it out from front and if you don't want pul it out from front just open up the cover of roller then take off the paper.
you are done
Good luck
Feb 09, 2009 | Office Equipment & Supplies
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
151 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
