Question about Irons
GCSBBV-151 Sunbeam Classic Iron
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
My sunbean iron gcsbbv-200 is not working
laundry.manualsonline.com has free manual
Jun 24, 2014 | Sunbeam Irons
Cleaning non stick soleplate on iron
Soak in vinegar until softened wipe off. If needed use rough side of a sponge or SOS pad to aid removal.
Jan 25, 2014 | Sunbeam Classic Iron - GCSBBV-212
The snap on cover on my handle for my Sunbeam Classic 3956 iron is cracked. Can I get a replacement?
go and try with this link :http://www.fixitclub.com/parts-components-repairs/
God bless you
Oct 01, 2013 | Sunbeam Classic 3956 Iron
I bought a Sunbeam Iron a week ago and paid $16.94 plus tax. I have used it 3 or 4 times and I am very disappointed in it. The Model No. I bought was GCSBBV-101. I can't take it back because I have already...
If it is only a week or so old it should still be in warrenty guarentee. Take it back and if it is a good retailer, he will change it or do a refund.
Jul 03, 2009 | Irons
Open Iron
on most common IRONS , theres a screw located on the back where the main cord is , underneath it , AJ
May 15, 2008 | Sunbeam Classic 3957 Iron
Water leaking from iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Feb 06, 2008 | Sunbeam Classic 3964 Iron with Auto...
Irons Logo
106 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
