Question about Aquacal HEAT PUMP 120,000 BTU H135 -
The second digit of the temperature gauge has missing segments
Does the entire control unit have to be replaced?
Does the 98 Ford F-150 5.4 triton have two coolant sending units? I found the one on the intake and replaced it and still no gauge.
Has CHT - cylinder head temp. sensor . This sensor is a input to the PCM - engine computer . The PCM sends engine temp info on serial data network to the instrument cluster . I/C has a microprocessor inside . Have it check for DTC'S - diagnostic trouble codes . Not OBD2 codes , B - body codes . The gauge could be the problem , which means replacing the instrument cluster .
Engine coolant temperature information is received by the instrument cluster from the PCM over the SCP network. Temperatures over 121°C (275°F) will display hot (H). If the engine coolant temperature data is missing or invalid for five seconds, the instrument cluster will move the engine coolant temperature gauge below the cold (C) position.
The best way to diagnose this is with a scan tool , factory or a professional type . Know how the system works and not replacing parts is the proper way to diagnose .
U1073 D073 SCP (J1850) Invalid or Missing Data for Engine Coolant PCM CARRY OUT the PCM self-test.
  • A single gauge does not return to zero with the ignition switch off
  • Instrument cluster.
  • INSTALL a new instrument cluster; REFER to Instrument Cluster . TEST the system for normal operation.
  • Incorrect temperature gauge indication
  • Circuitry.
  • PCM.
  • Engine coolant temperature sensor.
  • GO to Pinpoint Test F .
I should also point out that if the temp sensor were bad the vehicle may not run right .
Using the factory scan tool
Trigger instrument cluster active command ENGCOOLNT. Monitor the engine coolant temperature gauge while adjusting the ENGCOOLNT active command to read 50% and 100%.
  • Does the temperature gauge start at cold, move to half at 50%, and full hot at 100%?
Yes REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
No INSTALL a new instrument cluster; REFER to Instrument Cluster . REPAIR the circuit. CLEAR the DTCs. REPEAT the self-test.
Your best bet , take it to a qualified repair shop !
May 29, 2017 | Ford Cars & Trucks
Temperature gauge not showing any temperature
The sensor has nothing to do with the temperature gauge. That is controlled by a sender unit (1 wire) that changes the electrical resistance to current passing through the gauge. Remove the wire from the sender unit and earth it out. and if you have power through the gauge it will immediately go to hot. IF it does then replace the sender unit.
Apr 25, 2014 | 2006 Pontiac G6
I replace the temperature sensor and now my gauge is not working why
The temperature sensor has nothing to do with the temperature gauge . The temp sensor controls the fan operation and the CPU operations while the temp gauge sender unit is a heat controlled resistor that alters the voltage through the gauge. check that you have replace the wires on the correct unit .
Feb 17, 2014 | 2005 Buick Rendezvous
Engine coolant Temperature gauge fluctuates
Watch the temp gauge when the electric radiator fans come on. The temp sensor that controls when the fan comes on may be faulty.
Oct 11, 2012 | 2000 Pontiac Bonneville
After disconnect and reconnect the battery of my opel antara, the indication of odometer displays only 888... for all indications. How can i reset it?
This solution will be of great help to you,even in the case of future or other dashboard problems;
Instrument cluster consists of electronic analog gauges, various warning lights, and optional tachometer. Vehicles equipped with tachometer have an electronic vacuum fluorescent transmission range indicator (PRND3L),odometer and trip odometer display. Vehicles without tachometer are equipped with a cable-operated transmission range indicator.
Instrument cluster is equipped with the following warning lights:
Battery voltage.
Cruise (speed control).
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Low windshield and washer level.
Traction Control.
The Body Control Module (BCM), which receives input from various sensors, sends display information to instrument cluster and operates gauges. Instrument cluster incorporates a self-test diagnostic feature to identify electronic problems. BCM, Powertrain Control Module (PCM), and Transmission Control Module (TCM) are continuously monitored by the diagnostic system.
SELF-DIAGNOSTICS
With ignition off, press and hold TRIP and RESET buttons while turning ignition switch to ON position. Continue to hold TRIP and RESET buttons until odometer window displays CODE (approximately 5 seconds). If problem exists, system will display diagnostic trouble codes. See DIAGNOSTIC CODE CHART table. If no problem exists, Code 999 (end test) will be displayed.
CodeDescription
110.......Cluster Memory Fault
111.......Cluster Calibration Fault
905.......No CCD Bus Message From TCM
921.......Odometer Fault From BCM
940.......No CCD Bus Message From PCM
After diagnostic code display ends, instrument cluster will go into each of the following tests in order:
Dim test.
Calibration test.
Odometer segment test.
Electronic Transmission Range indicator segment test.
Dim Test
CHEC-0 will be displayed in odometer window. Instrument cluster will dim Vacuum Florescent (VF) display. If VF displays do not dim, a problem in instrument cluster exists. See BODY CONTROL COMPUTER TESTS in BODY CONTROL COMPUTER article.
Calibration Test
CHEC-1 will be displayed in odometer window. Each of instrument cluster gauges will move sequentially through each calibration point. See GAUGE CALIBRATIONS table. If gauge needle is not calibrated properly, a problem in instrument cluster exists.
Odometer Segment Test
CHEC-2 will be displayed in odometer window. Each segment of odometer will light sequentially. If any segment does not light, replace instrument cluster.
Electronic Transmission Range Indicator Segment Test
CHEC-3 will be displayed in odometer window. Each segment of electronic transmission range indicator will light sequentially. If any segment does not light, replace instrument cluster.
Sep 10, 2012 | 2007 Opel Antara 2.0
My nissan Almera S reg has no side lights or dash lights.All fuses seem ok.
Battery voltage.
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Traction Control.
SELF-DIAGNOSTICS
CodeDescription
Dim test.
Calibration test.
Dim Test
Calibration Test
Sep 10, 2012 | 2005 Nissan Almera 1.5
My Sharp R1505 Microwave's LED display is malfunctioning, with only minimal lighting of digital/number segments. Do I need to replace the entire control board with a new LED attached or can I just replace...
You can order a new control unit (part number CPWBFB075MRU0 which comes with a display) from Encompass here.
Or you can get yours repaired for $39.95. Details here.
Feb 10, 2011 | Sharp R-1505 Microwave Oven
Changing dashboard light
Battery voltage.
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Traction Control.
SELF-DIAGNOSTICS
CodeDescription
Dim test.
Calibration test.
Dim Test
Calibration Test
Aug 09, 2010 | 1998 Plymouth Voyager
My display numbers are upside down.
If this unit has worked before, and suddenly looks upside down, you are most likely seeing a display with missing or defective sigments. There are 7 segments needed to make number from 0 to 9. When a segment goes bad, you will see something different.
Sometimes the internal connections to the LCD display are dirty or corroded.
Oct 18, 2009 | Uniden Qt206 Thru Hull, Digital Depth...
2003 F-250 instrument cluster...
it sounds like you are getting a surge of voltage from your alternator/generator. Very strange.
the dealer can run a diagnostic test & pull fault codes or you can try this. If this helps, please report back & rate as fixya. Thanks. I am curious what you find as root cause. Good luck.
Instrument Cluster Self-Diagnostic Mode
To enter the instrument cluster self diagnostic mode with the engine off, depress and hold the odometer reset button. Turn the ignition switch to the RUN position and hold until the gauges sweep (within five to eight seconds). Depress the reset button once to advance to each stage of the self-test.
Turn the ignition to the OFF position to exit the instrument cluster self-diagnostic mode. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
Instrument Cluster Self-Diagnostic Mode Odometer display Description GAGE Carries out gauge sweep of all gauges, then displays the present gauge values. Also carries out the check sum test on ROM and EEPROM. All segments illuminated. Illuminates all odometer segments. bulb Illuminates all micro-controlled lamps and LEDs. r #### Returns to normal operation of all micro-controlled lamps and LEDs and displays hexadecimal value for ROM level (used when requesting assistance from the hotline). nr#### Displays hexidecimal ROM level and type as stored in non-volatile memory (NVM). EE ## Displays hexadecimal value for EE level (used when requesting assistance from the hotline). dt #### Displays hexadecimal code for the final manufacturing date. ###C Gas engines display last temperature gauge input value from SCP, temperature gauge will indicate present temperature. Diesel engine displays present temperature analog/digital input in decimal as a ratio, temperature gauge will indicate present temperature. dtc #### Displays a 16 bit DTC in hexidecimal format. DTCs displayed are those detected in continuous operation not during self-test. EnG Displays English speed value being input, speedometer will indicate present speed. m Displays metric speed value being input, speedometer will indicate present speed. tAc Displays the tachometer value being input to the instrument cluster. Tachometer will indicate present rpm. FUEL Displays the present analog/digital fuel level being input to the instrument cluster as a ratio. OIL Displays the last analog/digital reading of the oil pressure switch contact resistance, oil gauge will indicate present level. br Displays the brake fluid level in an analog/digital ratio value. bAt ##.# Displays present battery analog/digital voltage. rhEo Displays present hexadecimal pulse width modulation (PWM) dimming input. rhi, rhS, rho Alternating 1 second display of pulse width modulation (PWM) input duty cycle, SCP hexidecimal dimming step, output driver counts in hexadecimal. Cr RUN/START sense circuit check. PA, Pb, PC, and Pd Displays 8-bit hexadecimal value for the Port A, B, C, and D readings (used when requesting information from the hotline). PE0-PE7 Displays 8-bit hexadecimal value for the Port E0-Port E7 in analog/digital readings
Jan 26, 2009 | 2003 Ford F250 Super Duty Crew Cab
Aquacal HEAT PUMP 120,000 BTU H135 - Logo
21 people viewed this question
Top Aquacal Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Aquacal Pool and Spa Expert? Answer questions, earn points and help others
