Question about Dell 21" M1110 .22DPI 1600x1200 *SUPER SPECIAL* Monitor
Dell sp2208wfp CCF lamp is not working (no back light)...and the warrenty was expired. I am wondering if I can fix it by myself?
    Genius:
  • 2,120 Answers
Look for them on eBay. You can do it.
Posted on Jan 28, 2009
Dell monitor blue light on no display
Hook it up to a different computer or laptop. If it still has issues then change out the cable. Add more info: has it ever worked? When was the last time it worked.
Apr 14, 2014 | Dell 22" SP2208WFP Widescreen Flat Panel...
Screen and sound goes of for about 15 seconds and comes back on over and over again warrenty just expired
This symptom is dying lamp in tv, lamp has been reached to end of its life so replace it to solve the problem.
Lamp replacement procedure is written in user manual and buy Sony original lamp for good picture in tv.
Hope this will help.
Aug 29, 2011 | Sony KDF-E55A20 55 in. LCD Television
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
The LCD light (green) flashes for like 6 times and then the pictu
even though the lamp light is not flashing I would think it is the lamp getting weak for some reason the Sony's do that.
Aug 19, 2009 | Televison & Video
Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 05, 2008 | Dell 21" M1110 .22DPI 1600x1200 *SUPER...
I HAVE M675 GATEWAY
This could either be a defective CCF Lamp or the inverter that powers the lamp. In some instances, it could also be a simple case of cold solder/loose connection in the inverter circuitry or the connector to the lamp.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Apr 05, 2008 | Gateway M675 Notebook
Change Bearings
I will need the brand of washer as well as the model number.
Jan 15, 2008 | Washing Machines
Screen going off after 4 seconds
This is a typical LCD monitor problem. Here's a copy of my response to a similar issue /  post.
...If the power light stays on and the unit works even if for just a moment, then chances are that you either have a cold solder, or a heat problem with some components or your CCF Lamp is starting to fail.
All possibilities require that you open your LCD monitor and perform diagnostics of the components/circuitry inside. This of course would require that you be familiar with components, circuitry, soldering and the use of a VOM.
Cold solder - refers to soldered connections that have lost 100% of their connectivity. When the unit is jarred or after some time of use it looses completely its connection. The corrective measure require that the said cold solder be located and resoldered.
Heat problems with some components - the most often are power capacitors. These are can types rated something like 470uF/16V.  When power is applied and heat starts to build up, they start to looses their capacitance and therefore can no longer hold a charge.  Most cases, there are physical evidences such as blistering, brownish leakage at the top or at the bottom, swelling or gaps at the X/Y indentation at the top.
CCF Lamp - may involve the backlight or the inverter that powers it. A way to verify this is to shine a flashlight on the instance the screen blinks out at the screen. A faint image of your desktop should be visible.  The CCF Lamp is similar to household fluorescent lamp which of course can fail after some time of usage.  The inverter is a high frequency high voltage power for the lamp.
Since there are dangerous high voltages inside, extreme care should be practiced when working on exposed components.  Should you not be comfortable doing this, perhaps your best bet would be to seek the services of a qualified technician.
Hope this be of some help/idea. Pls post back how things are or should you need additional information.
Oct 24, 2007 | Dell 1707FPv Monitor
Dell 3300MP Projector
my advise is to get a new one or try ebay - i got my dell 3300mp NEW in box for under $400 - and have looked at other projectors there are very good deals on ebay but make sure you read the entire listing
Sep 13, 2007 | Dell 3300MP Multimedia Projector
Dell 21" M1110 .22DPI 1600x1200 *SUPER SPECIAL* Monitor Logo
359 people viewed this question
Alun Cox
