Question about Steinhausen Lifetime Watch Winder SM587
STEINHAUSEN LIFETIME WATCH WINDER repair - Steinhausen Lifetime Watch Winder SM587
Steinhausen tm-478 single watch winder how it worcks
Watch Winder Setting & Instructions for Executive Collection
Jared Tracy
posted this on March 30, 2012, 2:44 PM
  • inShare
  • There are four modes for our Executive Collection of Watch Winders (TM and SM series):
    Mode 1 (both switches with the O pressed in): rotates for 180 seconds on then 12 minutes off.
    Mode 2 (first switch with the O pressed in, second switch with the I pressed in): rotates 180 second on then 15 minutes off.
    Mode 3 (first switch with the I pressed in, second switch with the O pressed in): rotates 180 seconds on then 18 minutes off, then 180 seconds in the opposite direction.
    Mode 4 (both switches with the I pressed in): rotates 180 seconds on then 24 minutes off.
    For switching winding direction:
    I pressed in will wind clockwise
    II pressed in will wind counter clockwise
    Neither pressed in will turn the winder off
    *Please note that the CW and CCW settings do not apply when the winder is set to Mode 3 as this mode winds in both directions.
Apr 10, 2014 | Steinhausen TM-478 New Single Watch Winder...
How to change battery on TW493s steinhausen dunn horitzon quartz watch
The back screws on or it pops on by lifting it from a tab or indention. If there are slots on the back it screws on. Go to Harbor Freight an get the tool used to remove it. It is also avaiable on ebay. Just be careful.
Sep 26, 2011 | Steinhausen TW493S Dunn Horitzon Swiss...
1. tends to stop if you are not wearing it 2. tends to stop at particular times ie 12.20 3. can't rewind the time past certain times
Automatic watches will generally run for 2-3 days before they stop.
I have no idea what causes the other problems.
If you want to keep it going while you are not wearing it, you can buy a watch winder, which gives it enough movement to operate the self winding mechanism.
Aug 18, 2010 | Chase Steinhausen TW-381-G Classic...
Need switch settings for Steinhausen watch winder to suit an Omega Coaxial movement. I do not have the original manual, and I cannot tell how to set the switches to get the appropriate winding action for...
Leave the settings as for ordinary automatic movement. Co-axial movement has nothing to do with winding process - it was developed for more precise time keeping and friction reducing only, so, you can wind the watch in winder as usual.
Mar 26, 2010 | Watches
I need a manual or instructions for the mens
you can refer to the customer service on the Steinhausen homepage:
http://www.steinhausenonline.com or call free: 24/7(800)208-2607. they can offer you the best advice.
Dec 20, 2009 | Chase Steinhausen TW-381-G Classic...
Need instruction manual for steinhausen watch winder model TM384L
you can refer to the customer service on the Steinhausen homepage or call free: 24/7(800)208-2607. they can offer you the best advice.
Oct 21, 2009 | Watches
Winder is lost
You need a replacement stem and crown. I would replace the stem just to be sure you arent putting a new crown on a damaged stem.
Sakgen is very good about repairing their watches. Unfortunately this doesnt fall under their warranty but the repair directly through them is an average price for this part.
Generic after market crowns are also available at local watch repair shops. Make sure that if you go this route that you select a shop that can reseal the watch to is water resistance rating so you do not void your lifetime limited warranty on the movement. This mean they must have a pressure testing chamber and be able to supply printed proof of resealing.
Sep 23, 2009 | Skagen 355LGSC Wrist Watch
How do I reset the time on a Steinhausen Watch?
Jun 24, 2009 | Casio Atomic-Solar Watch GW300
How do I set time and date on my automatic Steinhausen watch?
moz-screenshot.pngyou can refer to the customer service on the Steinhausen homepage:
Aug 30, 2008 | Bulova Watch
Steinhausen Lifetime Watch Winder SM587 Logo
32 people viewed this question
Top Steinhausen Watches Experts
cwradio73
Geoff
Buddy lotter
Buddy lotter
Are you a Steinhausen Watch Expert? Answer questions, earn points and help others
