Question about Rockford Fosgate Punch P325.2 2-Channel Amp - 160W Punch Series 325W Bridged Mono Remote Punch Bas... Car Audio Amplifier
No power I swapped out my old amp which was working fine, for this RF one and I'm not getting any power on this one. I put it in my friend's car and it works fine. I put my friend's amp in my car and it works fine. Why doesn't the RF work in my car?
    Problem Solver:
  • 11 Answers
Hi, some car amps need a high current remote supply to turn on. first make sure that you are using the proper gauge b+ and gnd cable for this particular rockford amp. then try switching the remtote turn on to this amp thru a simple Relay.(use the remote supply from your headunit as a trigger for the relay). do these connections without connecting any spks or rca line inputs. once amp is switching on then connect all other cables. OR lastly check the main fuse on the RF amp?? cheers
Posted on Aug 05, 2007
SOURCE:
Is a boss ce2800 amp a good amp it says its 2800 watt class d mono block
It's over rated on it's specs and they run real hot when working hard. Make sure to located in an area with good air flow and away from material that may melt.
Nov 15, 2013 | Car Audio & Video
I had the car in storage for 35 days. Upon startup, battery was dead. I took the dead battery out(only 1 year old) and put in a good battery which started the car, while the car was running good I took out...
You recycle the old dead battery
Have no idea why you even put that back in
Common sense & your friend is correct
You don't disconnect anything on today's
vehicles, even with the key on
Put in a new battery,start the car, warm it up
& drive it for awhile & maybe you will get lucky
& it will complete some of the drive cycles & run some
monitors ,you know nothing about & it will be fine
If not, your mechanic friend should be about to stop
by with the bosses scan tool & help you out
Sep 23, 2011 | 1999 Acura TL
My eclipse amp DA 7122 doesn't put out any power, no fuses are bad and led lights up. I must have a short some where?...any suggestions
check your rca cables and remote wire or wires and also check the wires to the speaker and in the box and if you have a friend that has a set up in there car swap amps to see if it works any different if it dont you may be able to get it fix at a car audio shop.
Dec 28, 2010 | Eclipse DA7122 Car Audio Amplifier
Does anyone know how to set up an old nintendo game
I am assuming you mean a nintendo entertainment system (NES)
You Need:
The gray master console
At least 1 controller
Power supply
RF Switchbox (Must be an auto switchbox) or an A/V Cable with RCA ends
The power supply & RF switch plug into the back of the grey master unit. Hook the RF switch up to the cable connection on your TV. (If using the A/V cable - it plugs into the side of the master unit & into a video in - yellow plug/audio in - white plug) Plug in the power supply. Make sure a controller is plugged into the 1 outlet on the front. Make sure a game cartridge is inserted & locked in (You push it down). The TV needs to be on whatever channel the switch is set on if using the RF switch (Channel 3 or 4). Turn on the power & it should work
Jan 03, 2010 | Nintendo DS Console
Hi i got an xbox 360 with 3 red lights &
yea...ur gonna have 2 send that in 2 microsof...heres the # 2 call them 1-800-469-9269
Oct 28, 2009 | Microsoft Xbox 360 Console
Psp has power, but screen is black.
WAH what does this mean. then he swapped works right..lol than whats wrong with it! i dont see if he swapped it for a new then the old must be useless to you. but i dont know which screen ur talking about the one he installed or the old one! a broken screen is not worth even looking at bro just discard it! sorry it jsut when the screens go theres not much you can do due to the fact there is now real hardware in ot um ur friend may have jipped you
Aug 28, 2009 | Sony PlayStation Portable (PSP) Console
Amp gets very hot in as little as 5-10 min.
Whats the omh load and how old is amp??? The old Rf amps always got hot that how they worked.... No ventilation????
Nov 05, 2008 | Rockford Fosgate Punch 700S Car Audio...
When powered on protection light comes on
Protection usually means that there is a short some where. If it is inside the amp or external I couldn't tell you. You could check the fuse to make sure that isn't blown. I had a Memphis amp that blew both fuses and the protection light came on. I swapped out the fuses and worked fine, still works. If you have a multimeter set it to OHMs and check the resistance between the power terminals. It should be very high. If these things don't work then there is most likely something wrong with the amp or your power termination. I wasn't able to find a lot of information on this amp but if it has screw type terminals, did you use terminals. If you just put the wires in the terminals make sure there wasn't loose strands touching. I hope you can get this one.
-Andrew Hawkins
Mar 27, 2008 | Car Audio & Video
Rockford Fosgate 800.2 no power
This one is a real twister. Some questions of you might help to correct this problem.
1) Did you in some way hook the CB Radio up to the amplifier?
2) Did you use the same power lead from the amp to install the CB Radio?
3) In some way, did you unhook the ground from the amp?
These questions will help in solving your problem
I'll be waiting to hear from you
Ed
NC Electronic
Mills, Wyoming
Jan 29, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
Car Audio & Video Logo
119 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
