Question about Sharp Televison & Video
Does the Sharp LC-42D64U support ARC function?
pgh_pa_guy
  • 2992 Answers
SOURCE: Is it possible to replace a broken lcd screen on
Sorry to say, it's pretty much toast. The screen is most of the cost of an LCD TV, so if it gets physically damaged you're better off replacing the set.
Posted on May 08, 2009
  • 668 Answers
SOURCE: After a recent thunderstorm my
The Main board likely took a surge. It would need to be replaced. It is not a repairable Board. Best thing to do is to contact Sharp at 1800BESHARP and see if they can get a Sharp Servicer to help you.
Hope this helps,
skyassoc
Posted on Jun 20, 2009
  • 187 Answers
SOURCE: sharp LC-42D64U 42 inch, turns off and blinks
Mainboard damaged and need to be replaced
Posted on Jul 09, 2009
satavlad
  • 405 Answers
SOURCE: No sound from ps3 when connected with hdmi to
on your PS3 go setting>sound setting> audio output settings to adjust settings for the audio device (OPTICAL or HDMI)
Posted on Dec 06, 2009
bshldn
  • 736 Answers
SOURCE: My problem is when I
On the Vaio:
right click volume on system tray and select playback devices
select hdmi/ sdip as default and then in the properties deselect dolby
If you don't have those options you may need new drivers installed on your Vaio. Do you have windows xp? The driver can be found here: support.vaio.sony.co.uk/downloads/info/info.asp?site=voe_en_GB_cons&url=Vaio/Original/AR2_Drivers.zip&ip=RAID_AR21.htm
If you have vista the driver can be found here:
support.vaio.sony.ie/downloads/updates/updates.asp?site=voe_en_IE_cons&c=0&s=VGN-AR&m=2418&os=7&osl=1
On the television make sure you are on the right input. Press menu--setup--hdmi setup--audio select--digital
Hope this helps
Posted on Oct 08, 2010
Testimonial: "Thank you very much! Just the first phrase was enough!!!!"
I have Sharp TV Model LC-42D64U sound cuts out after two hours or less. Sound only comes back after leaving TV off for about an hour.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Feb 23, 2017 | Sharp LC-42D64U - AQUOS 42" High-def 1080p...
Sharp TV Model LC-42D64U.
Use the button called View Mode on the remote to go to the menu for this function
Apr 22, 2014 | Microwave Ovens
Connect a Sharp TV to Sharp sound bar
Call a local custom audio/video installer that can help you for a small fee. It's okay to pay a professional and get the right help. It shouldn't cost you more than $50 at most, but probably half that amount since it's a very simple connection.
Here's a couple of weblinks that may be helpful...
http://hometheater.about.com/od/hometheaterglossary/g/Audio-Return-Channel-Arc.htm
http://www.sharpusa.com/ForHome/HomeEntertainment/SoundBar/Models/HTSB40.aspx
Dec 03, 2013 | Televison & Video
Darker screen on the right hand side of my Sharp
try going to menu and center the screen both vertically and horizantal, the manual should help
Feb 25, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound from ps3 when connected with hdmi to sharp lc-42d64u lcd, connected to sony dav-hdx589w via digital optical cable
Dec 05, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
Is it possible to replace a broken lcd screen on the Sharp LC-42D64U or is it just toast?
May 08, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Stereo/Mono Fluctuation Screen Display Problem
I had the same problem.
All I did was unplug the standard cable wire from my tv and used RCA cables to connect my TV to my digital cable box the the Input 1 jack in the back. It also increased the video quality.
Aug 07, 2008 | Sharp LC-42D64U 42 in. LCD HDTV
My tv shuts off by its self then wont restart until it is unpluged for a while then it shuts off again.
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.
Dec 26, 2007 | Sharp LC-42D64U 42 in. LCD HDTV
Televison & Video Logo
161 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
