Question about Pool & Spa
My kreepy krawly sucks but doesn't move. Have backwashed and wasted the pool, and there is suctrion from the kreepy
2 Suggested Answers
  • 8404 Answers
SOURCE: My swimming pool filter returns dirty water to the
Might you have a broken lateral in the bottom of your filter and what you are seeing is sand coming into the pool?
Do you backwash daily or more often? (You should) Do you have a multi-port vavle or other type?
Im thinking broken lateral. Sucking air in and of itself will not cause dirt to return to the pool.
Whats a lateral? There is a series of pipes in the bottom of the sand with small holes in them. These holes allow water to travel in and out depending on whether you are filtering or back washing ... but not sand. If you have sand, you have a broken pipe.
Open the filter and remove the sand into a bucket to inspect the laterals.
I hope this works for you.
a
Posted on Oct 19, 2009
My hurlcon CX 240 pool pump has good return pressure but very low suction from the pool and wont opperate the kreepy krawly, Do I need a new pump? Thanks. Richard
no
what you may have is a blocked outlet--filter --tap incorrectly set
good pressure but no suction indicates that the pump is pumping but the pumped water has nowhere to go
Jan 05, 2017 | Pool & Spa
Hurlcon pool pump. Lack of pressure. Creepy crawley will not pulsate. Pump working at 110 pressure - no change. Checked all joints with soapy water.
When you mention the 110 pressure with no change are you saying that the pump is operating at the same level as before and the Kreepy was functional with this level of pressure before? If this is the case then your problem is with the Kreepy itself. This sounds like something is in the Kreepy Krawly line or the unit itself. Many things can become lodged in the unit like acorns, bottle caps, or simply there is a leak in the vacuum hose. I would investigate the unit for impeding debris.
Dec 24, 2015 | Pool & Spa
Kreepy krauly
If you have the round one I\'m not sure what is wrong, but if you have the one with the wide wheels in front and back, it\'s just the brushes making noise on your liner. It doesn\'t actually suck air. hope this helps.
Nov 08, 2013 | Pool & Spa
I have great water pressure in my pool, but the minute I attach my Kreepy Krawly, the pressure drops and there is a large vacuum in the pump reservoir. the Kreepy hardly moves at all thereafter.
It sounds like your you might not have all of your suction lines closed. Check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached. If this is not the problem, it could be that the pool pump and filter system that you have may be too small It should be capable of providing at least 25 gallons per minute. These are common issues with these pool cleaners.
Feb 02, 2011 | Universal Kreepy Krauly In-Ground Pool...
I took my creepy apart and I can't get it back together. Could I have a schematic?
Your picture says that you have a baracuda, but if you have a kreepy I can help. Here is the owners manual for the Kreepy Krawly. These automatic pool cleaners are not hard to get back together with instructions.
http://www.backyardcitypools.com/images/pentair/kreepy_krauly_manual1.pdf
Jul 15, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac Baracuda Zippy Pool Cleaner only clean one pool side because strong jet don't let move to other side
If you don't have directonal eyeballs on your jet's you can get a dirveter for the jet that will push the water down the wall rather than out into the pool. Get these at your local pool store. Baracuda and Kreepy Krawlie both make them.
Jul 05, 2010 | Zodiac Baracuda Zippy Pool Cleaner
My Kreepy Krawly always gets stuck!
You will get a current going in the pool that will drive the cleaner into some spots that it can't get out of. The steps are a good spot for this.
If you move the return eyeballs around usually point them down this will help. This will stop any action on the surface of the pool as far as pushing things into the skimmer but the action of the hose jiggeling should help to break the surface tention of the pool and get leaves and such to sink so the cleaner to pick them up.
If you don't have eyeball returns then you can get dirveters that slide into the return lines to break these currents for you.
Hope this helps and good luck.
Feb 12, 2010 | Universal Kreepy Krauly In-Ground Pool...
My kreepy krawly stays on the side of the pool and wont clean the bottom.I have placed the weights in the correct position. Any suggestions?
Try no weights.
Try weights in a incorrect position.
How is the hose....is it flexible......is it steering it to the sides and keeping it there?
Sep 30, 2009 | Universal Kreepy Krauly In-Ground Pool...
Pool & Spa Logo
22 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
