Question about RCA 3-Device Universal Remote
Dta800 with 1991 Emerson tv
I entered all 35 Emerson codes & can't turn tv on or off with dta800 remote. I am having to use the Emerson remote to turn tv on/off.
  • sm5669 Feb 07, 2009
    I have a 2002 emerson model ewc1302 and I have tried all the remote codes listed with the RCA DTA800B1 for emerson and none work.  I also tried about 100 other codes and nothing works.
  • 47buick Feb 13, 2009
    I tried the Funai codes & they didn't work either but thanks for the suggestion. Maybe this TV is just too old for codes to work
  • RCA Master
  • 5,568 Answers
Your Emerson could have been built by Funai who now owns the name rights in the US.
Try any codes you might have for either of that name.
In addition:
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
There may never be a code for your brand available in every remote.
Posted on Feb 08, 2009
Can't find the codes for my emerson tv codes for
Instructions
    • 1Remove the battery cover and insert new batteries into the remote. Press the "Power" button on the television to turn it on.
    • 2 Press the "PRM" button that is in the lower left corner of the remote control. You should see the signal indicator light come on.
    • 3 Click the DTA800 TV Codes link in the resource section to view a list of program codes for the converter box. Enter the 3-digit code for your television by pressing the number keys on the keypad. Press the "OK" button when finished. You should see the indicator light turn off.
    • 4 Point the remote at the television and press the volume keys on the remote control. If the volume for the television changes, the remote has been programmed successfully.
    • 5 Enter another 3-digit code for your television if the first code fails to program the remote
    • CODES : Emerson
      • The RCA Universal Remote has 17 different codes for Emerson televisions. These codes are 011, 026, 027, 028, 029, 030, 031, 032, 037, 042, 053, 064 065, 067, 075, 076 and 079. There are 18 different Emerson VCR codes. These codes are 008, 009, 010, 013, 015, 020, 023, 027, 034, 041, 042, 047, 057, 062, 065, 067, 068 and 070. There are no codes for Emerson cable boxes.
      Hope this helps. =)
Sep 30, 2014 | Televison & Video
Trying to program Uverse remote for Emerson 32 flat screen
i install uverse, the auto seek is done by hit and hold TV and OK. wait for lights to flash enter 900 and push play over and over SLOWLY and when the tv turns off, press enter.
NOTE: some tvs WILL NOT program to our remotes
Jul 04, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I have a at&t uverse remote and am trying to program it to my emerson tv,but i dont have the codes
Go to their website to find out a download copy of the codes if not just buy a new one.
Jun 29, 2010 | Televison & Video
I need to program my at&t uverse remote with the Emerson 19 inch TV/DVD. I do not have a code.
Dec 25, 2009 | Emerson LD195EM8 19 in. LCD TV
Need to find the code # for emerson tv for easy one for all remote we want to program remote with emerson tv i think it a 4 numbers?
To control an Emerson TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0154, 0236, 0463, 0180, 0178, 0171, 0623
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
Hope that helps.
Oct 18, 2009 | One For All URC-3021 Remote Control
Need additional remote codes for emerson tv - codes listed on
Hi if you haven't already, try these codes: -
000, 127 or 141
Sep 07, 2009 | Hughes HRMC11 Remote Control
Have emerson 20 inch tv and have a one for all universal remote need code for tv
to get the code for your tv with a universal remote put on your tv manually press search code until the light comes on. push the tv button on the remote. then you constantly press the search code button until your tv switch off.when tv turn off press the enter button to save the code. good luck.
Mar 05, 2009 | Emerson EWF2004 20" TV
CODE FOR A REMOTE CONTROL
I am not sure of the model remote but, on the newer TW remotes you would press tv then press and hold set up until the tv light blinks twice. then enter 991 on the number pad and then press power once. then press the channel up button until the tv turns off. as soon as it turns off - press the power button and if it turns on then you have the right code. If it doesn't turn on then press channel down until it turns on. either way, when the tv turns on then press set up again to lock that code in. Hope that helps.
Feb 10, 2009 | Emerson Televison & Video
Emerson
Try using 051. I just found it online, used it and it worked!!!
Dec 11, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 14, 2007 | One For All URC-3021 Remote Control
RCA 3-Device Universal Remote Logo
133 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
