Question about Acer TravelMate 2300 Notebook
Nonething on monitor but flashing cursor
Lost
Cannot remove novo vision from flashing on my monitor
Press the power button of the monitor for a few second in 'of' mode then 'on', the popping add on the windows will just disappear.
This help solve my problem.
Jan 22, 2013 | Computers & Internet
Language
Press the FUNC button. Use cursor-up/down to select Display Setup (the monitor icon). Use cursor-left/right to select the speech bubble icon.
Oct 09, 2012 | Canon LEGRIA FS200 (32 GB) Flash Media...
Samsung 931bw screen flashes on and off
unscrew the back cover of the monitor then remove to access the power supply board, look for a leak or blown up electrolytic capacitor. just replace with the same rating and value a panasonic brand of capacitor much better with low esr.
Jun 28, 2012 | Computers & Internet
Today i played with my mobile nokia 5530 xpress music till its battery got emty i came home and tryed to recharge but nonething happens when i put the recharger in to hole and hold start it gives me little...
first check the phone by connect another battery if the phone is ok then your battery is full down u have to give direct 7walt dc current to battery for a min and charge it threw phone
Apr 17, 2011 | Nokia 5530 XpressMusic Smartphone
My cursor use to move from my primary monitor to my secondary monitor in the direction that my monitors are positioned on my desk. Now i need to move my cursor in the opposite direction to my secondary...
easy enough, go to display properties, where the icons of both monitors are displayed, and drag the monitor on the right to the left of the other monitor, Viola! fixed
May 17, 2010 | Computers & Internet
How do you turn off the flash on samsung sl202
When the menu is displayed on the LCD monitor, pressing the LEFT button makes the cursor shift to the left tab. When the menu is not displayed on the LCD monitor, the LEFT button operates as the FLASH ( ) button.  Selecting the flash mode 1. Select a desired Recording mode, except the [Movie] mode and the [DIS] mode. 2. Press the Flash button until the desired flash mode is displayed on the LCD monitor 4268flashicon.jpg The flash does not fire. Select this mode when capturing images in a place or situation where flash photography is prohibited. When you capture an image in poorly lit conditions, the camera shake warning indicator ( ã ) will appear on the LCD monitor.
Oct 24, 2009 | Samsung SL202 Digital Camera
Monitor Problem VS. Windows XP Problem
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 18, 2008 | Mag Innovision LT776s 17" LCD Monitor
Flash
the left tab.
■ When the menu is not displayed on the LCD
( ) button.
● Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING
mode with the exception of MOVIE CLIP mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
