Question about GE 24 in. GSD6660GSS Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
My dishwasher fills with water. The next step is that the sprayers are supposed to start. That doesn't happen. After a few minutes the water drains. The cycle is going on even though there is no water being sprayed.
  • conwaypr Feb 08, 2009
    Same problem- here are the steps: close door, press button, water fills, then low humming sound, after a while, water drains. no cleaning no rinsing. Sometimes the lights on the panel will go out, sometime they stay on.
  • Anonymous May 03, 2009
    MY DISHWAHER DOES THE SAME THING FIL BUT DOESNT CLEAN THEN EMPTYS AND DRYS. NO ACTIVITY
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Posted on Apr 19, 2009
SOURCE:
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
SOURCE: Dishes not cleaning particularly on top rack
Thank you, so much, for the update!
Lita
Posted on Jun 18, 2008
  • 28 Answers
SOURCE: Asko1585 sprayer arm not working
Most likely the circulation pump. On this pump there is mounted a condensator. This will help the pump to get started. If this is broken, it wont circulate the water up to the sprayers.
Posted on Jul 27, 2009
MNfisherman
  • 11896 Answers
SOURCE: upper spray arm on dishwasher does not move
you most likely have gunk inside the arm or holes not allowing the water to spray out and turn the arm. Otherwise, the arm bearing may be stuck and will need a gentle push to loosen up.
Posted on Sep 22, 2009
My GE Dishwasher model GSD1300N10WW doesn't clean dishes,glasses and silverware. Everything has a film on it. I think the tower sprayer might not be popping up but cannot tell.water does spray from the...
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Maytag Dishwasher
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Dishwasher fills with water but does not "spray water" on dish
Here are a few things that might help you out, first is you could have a bad heating element in your dish washer, when it fills with water it has to reach a certain temperature before continuing to the next cycle, next thing is you could have a bad thermostat, or your timer is defective.
Mar 16, 2009 | Kenmore 16522 Built-in Dishwasher
Ge Triton XL Dishwasher Fill Problem
I would check your fill valve screen, where your water line connects to the dishwasher, lots of times i will see that screen clogged, especially on customers homes that have wells.
There is no way to change the fill time on these.
There is also the potential problem with the float sticking if it is gunked up it will not allow water in...see that it moves up and down freely and you should here a clicking noise.....If it is not one of these there could be a problem...with the timer...I am providing a link that will help walk you through this problem in a more technical...manner...if you are not comfortable performing these tests...i suggest you forego it and let a tech handle it....
http://www.applianceaid.com/dish.html#filling (http://www.applianceaid.com/dish.html#filling)
this is one continuous link.....you can scroll down until you see the won't issue.
I hope this helps ..good luck, have a good day& please rate my effort......The Fang
Dec 31, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Triton XL Dishwasher not cleaning glasses
Check to see if the spinner holes are clogged with food..or debris...this is what makes the sprayer arms move....water pressure...which is pumped up through the sprayer arms .......I s the pump working...if so....then you may also have some blockage at the base of the pump where the screen is that keeps impurities out of the pump....check to see that food or debris is not obstructing this.
I hope this help....have a good day and good luck...please rate my effort...the Fang
Dec 14, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishes not getting clean in GE Triton XL Dishwasher
HI
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Oct 12, 2008 | Dishwashers
Dishwasher detergent left in dispenser cup on GE Profile dishwasher
there is no solution for it because of its design. i have same GE and same problem. It is happening because top rack is right front of the detergent cup and it is not opening 180 degree while it is washing. it opens only 15 or 20 degree and water just doesnt get in there as much as suppose to be because only water can get in there from the bottom sprayer arm because detergent cup lid is not allowing water to get in the cup from middle and top sprayer like any other dishwasher! i called them so many times and they are just jerks! they blame anyting about my house but their dishwasher. their tec. showed up 4 times and they just keep blaming hot water temrature etc. water temprature doesnt matter if water cant get in the detergent cup, right? but they dont want to admit that because they are like programed robots to give you same answers and just blame you but GE dishwasher. please fill out complain form with Consumer Complaint Department. you should be able to find their address and web site on the internet. Please do so, maybe we can get refund or replacement or something. Never ever buy GE again. Just get a Bosch.
Apr 14, 2008 | GE Dishwashers
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
1,121 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
