Question about Toshiba Satellite A105-S4004 Notebook
Hi I got a Toshiba Satellite A105-S4004 that auto reboots and displays nothing on the screen.
  • Dusty Colvard
    Dusty Colvard May 11, 2010
    When turning on your toshiba as soon as the bios screen exits start hitting F8. A menu will appear. select disable automatic reboot on error. you should get a blue screen with an error code. please post the error so that I can help you further
TOSHIBA Satellite A105-S4004 doesn't boot
unfortunately older models such as the a105 do not have a recovery partition. however recovery cd's are around 25 dollars if you contact toshiba directly
Oct 27, 2009 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Jun 23, 2009 | Toshiba Satellite A105 Notebook
I have a satellite a105 s2716 and the lcd only works when in dual display mode... also seems to be a conflict with using dual displays, resulting in reboot cycle
Hi, the conflict that your equipment presents does not refer to the driver that this installing, refers to a fault of hardware which does not allow that the card of video give image to the LCD, and by the same situation when forza the video the equipment it is restarted, the solution to your problem is to replace the card of video.
Dec 05, 2008 | Toshiba Satellite A105-S4004 Notebook
Need a motherboard for Toshiba Satellite A105-S4004
http://www.google.com/products?hl=en&q=Toshiba%20Satellite%20A105-S4004%20Motherboard&um=1&ie=UTF-8&sa=N&tab=wf
Jun 29, 2008 | Toshiba Satellite A105-S4004 Notebook
Display Problem
Try connecting an external monitor if this also shows a "bad" picture then probably the graphics chip on the laptop is faulty.
Mar 14, 2008 | Toshiba Satellite A105-S4004 Notebook
Cracked Screen
The backing of the screen will stay. You'll only be receiving the lcd.
http://www.fonerbooks.com/laptop_4.htm
Mar 08, 2008 | Toshiba Satellite A105-S4004 Notebook
A105
There was a hardware failure / problem on your laptop. If I'm not mistaken it's probably on the Memory Module.
Thanks,
Mar 01, 2008 | Toshiba Satellite A105-S4004 Notebook
LCD Display problem
THE WIRING OF UR SCREEN IS DAMAGED GET IT REPAIRED BY A PRO
Nov 24, 2007 | Toshiba Satellite A105-S4004 Notebook
LCD display problem
My Toshiba Satellite does a similar thing, It goes gray while I am working on it. The only way to continue to work on it is to complete shut it down manually and reboot. I took it to Toshiba they said nothing was wrong.
Oct 19, 2007 | Toshiba Satellite A105-S4004 Notebook
Blanck Display
Don't forget that there is a switch that toggles the display from internal to external display (possibly Fn+F5).
Sep 05, 2007 | Toshiba Satellite A105-S4004 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
