Question about Onkyo TX-SR607 Receiver
Onkyo TX-SR607 wont play Aux sound
My receiver will play dvd/bd and other forms but I cannot get any sound when I plug a computer, I pod or phone into the receiver any longer. Also when I turn up the volume I can hear it through the speakers every notch I go up, it makes a short sound and never used to do that.
  • 4 Answers
SOURCE: connecting a wii to an Onkyo TX-SR607 7.2
I am experiencing issues like this although with a VCR connected with analog video. I added a BluRay DVD player and all of a sudden I lost my video upconversion from my VCR. I am going to try to reset the receiver to see if this fixes the problem. If not, I don't think it is the receiver issue, I think it may be the fact that enorder for video to pass through HDMI, allot of criteria needs to be met. Certain Handshakes need to happen, especially with the HDCP issues. Most likely I will connect a separate video cable to my Plasma and use a secondary input on the Plasma for the VCR signal. You may want to purchase the Component Video adapter for the wii system as this will provide you with at least 480p and your receiver should not have an issue passing the signal over the HDMI output. Good luck and give me an update.
Posted on Jun 17, 2009
SOURCE: Onkyo TX-8211 receiver with very low volume through speakers
It's the Tape 2 button - unclick it.
Posted on Jul 09, 2009
ProColorTV
  • 25 Answers
SOURCE: I have a Onkyo TX-SR604 Receiver. I get no sound
Hello Fixya customer,
Thank you for your question.
A point to keep in mind here is that Zone II will only feed through an analog source. Since the Video 1 input is using the digital (coax, optical) input that that is your most likely issue.
Thank you for using Fixya, and please let me know if I can firther assist.
Posted on May 01, 2010
  • 46 Answers
SOURCE: Rear Speakers no Sound.
The rear speakers will only work when the Dolby signal processor or one of the 4 sound fields has been selected. In other words, the rear speakers won't "work" when listening in just Stereo, and this can happen if the "By-Pass" button on the front of the receiver has been engaged.
Posted on May 16, 2010
smarthome2
  • 1114 Answers
SOURCE: Onkyo TX-SR607 keeps turning off
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
How do I disabled the standby on my onkyo av receiver TX-SR607
Hi Ms Cazarez, all of our receiver go to standby when powered off as such there is not way to disable the feature unless you just unplug the unit form the AC outlet, Thanks, JT
Mar 14, 2015 | Onkyo Audio Players & Recorders
Had a power surge and now my Onkyo TX-SR607 will not power on. Only get a constant click sound. Any repair advice?
although power surge can trigger activations of protection circuits,
there are at times, damage is done before it is activated.
• Check first for low power supply regulators,
then check for possible output stage failure.
let me know if you need further assistance!
Sep 09, 2012 | Onkyo Tx-sr607 7.2-channel A/v Surround...
We are having HDMI handshake problems between our Onkyo TX-SR607 and our Sony KDF-55WF655 LCD Projection TV. The problem is intermittant. Sometimes it comes up just fine, and other times the screen is...
Hello, I am sorry for your issue. Haw long is the HDMI cable from the receiver to the TV? Have you tried a different cable/ Thank you, Onkyo USA
Jul 03, 2017 | Onkyo TX-SR607 Receiver
Lost colors when using composite cables with Wii
puedes subir o bajar la resolucion de tu t.v o pantalla ya que algunas son HDMI u otras FULL HD probablemente no este bien ajustada o los cables no estan funcionando bien o estan trozados,....
May 02, 2010 | Onkyo TX-SR607 Receiver
Powered sub only has sound while watching a dvd or listening to music on Onkyo TX-SR607
So perhaps it's a source sound issue. THAT would best be investigated at the Dish receiver. Consider it's audio settings and how it interfaces with the Onkyo.
Apr 25, 2010 | Onkyo TX-SR605 Receiver
I hooked up our Onkyo TX-SR607 system a few weeks ago and have watched several movies, but now I cannot get the Hitahci PH35811 TV to sync up to get video. I get audio, but no picture when we try to watch...
Are you routing the video into your reciver from the dvd player? If so route the video directly into your tv. It won't fix the initial problem but you will get picture and sound to watch dvd movies.
Feb 13, 2010 | Onkyo TX-SR607 Receiver
How do I link my Onkyo TX-SR507 to a PC?
It sounds like you don't fully understand the Onkyo's HDMI port assignment procedures.
But why burden an HDMI cable with audio only? Don't you have a coaxial digital or spdif optical output on the PC you could use? That would make things simpler for setup. Just jam it into one of the appropriate audio inputs on the Onkyo.
Jan 28, 2010 | Onkyo Tx-sr507 A/V Receiver
No video output from Onkyo receiver
Hello, I am sorry about your issue. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Jul 10, 2017 | Onkyo TX-SR607 Receiver
Connecting a wii to an Onkyo TX-SR607 7.2
Jun 06, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR607 Receiver Logo
83 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
