Question about Exercise & Fitness
How to adjust resistance level on Ironman 250e elliptical
I have misplaced my owner's manual and am unable to set the resistance level. Does anyone have this available?
SOURCE: Missing Owners Manual for the Ironman 250E Ellipitical Trainer.
I was having the same problem as my owner's manual has been misplaced as a result of several moves and I found this online. Hope it helps.
http://www.academy.com/images/pdf/Ironman/Ironman_Elliptical_530e.pdf
Posted on May 05, 2009
maxtreadmill
  • 832 Answers
SOURCE: Just bought my Proform 490 LE elliptical 1 day ago
If you purchase from a store I would take it back and exchange it, or if you purchased it on line then the manufaturer and have send somebody out to take care of this situation you have a warraty on the unit
Posted on Mar 13, 2010
taran_2005
  • 10515 Answers
SOURCE: We have a REFLEX Step
I had a similar problem recently with my elliptical - it was permanently stuck in the "hard" position. In my case, it has a wheel that turns when you step, and the tension is adjusted by a pair of magnets inside this wheel assembly. These magnets are positioned near the wheel - closer for more tension or further for less tension.
The console control electronics that send a signal down to this wheel assembly. There is a little motor that pulls on a short cable to position the magnet(s).
The problem was that the cable attached to one of the magnets snapped, leaving that magnet close to the wheel, i.e. high tension. We had to have a technician order and replace the entire wheel assembly as its individual pieces are not made to be serviceable.
It sounds like your case might be similar. Maybe you only have one magnet or two. In any case, I'd look at whether the magnet(s) are moving relative to the wheel when you adjust the tension settings (you should be able to see or hear the magnets move - you might need a buddy to help).
While you may not be able to repair it yourself (you can get yourself pinched badly around these gears and mechanical elements), you will at least know what's going on so you get the right work done if you choose to hire someone.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 01, 2010
ercupa190
  • 12223 Answers
SOURCE: My Pro-Form 330 elliptical has a resistance
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Posted on Nov 28, 2011
ercupa190
  • 12223 Answers
SOURCE: why does the resistance on my elliptical randomly go to OFF while working out
Do this for your console Elliptical:Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replace the left and right disc shields and sideshields. Reattach the ends of the pedals to the crank axles
Good luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Dec 06, 2011
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
Ironman 530e elliptical
Try a different category for your question. Not likely to get help in the sewing machine community.
Mar 23, 2017 | Sewing Machines
Bladez elliptical
see the steps and fix it. God bless you
Adjust the magnet with bolt attached there are loose, tight very well and ready the resistance is the main parts that need repair,
However if the resistance is faulty, you must test again the magnet from the refrigerator by attracting or repeled, if do not pass this test replace it buying small cheaping from home depot or similar.
GoD BLess you
  • 1 Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2 Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • Sponsored Links
  • 3 Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4 Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5 Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Read more: How to Fix an Elliptical Machine ' eHow.com http://www.ehow.com/how_4681374_fix-elliptical-machine.html#ixzz2DLrv9YSH
  • Sponsored Links
    Nov 25, 2012 | Bladez X350P Elliptical
    I have Life Fitness X3 elliptical machine, and when I start pedalling/striding the level setting goes to
    adjust the magnet, tight the bolts with wren. Test the magnet, with the magnet from refrigerator, for repel and attract, if donot, replace.
    The resistance depende of it.
    sincerely. God bless you
    May 06, 2012 | Life Fitness X3 Elliptical Cross-Trainer...
    How do I fix my crosstrainer, magnetic resistance has stopped working
    This happened to me and I took the wheel mechanism cover off to discover the tension motor cable had come out of it's pulley guide- so there wasn't enough tension left in the cable to pull it away from the wheel- quite an easy fix for me- hope it is the snake for you!
    Feb 15, 2012 | Exercise & Fitness
    Why does the resistance on my elliptical randomly go to OFF while working out
    E.CUADRA
    Dec 06, 2011 | Exercise & Fitness
    Resistance level does not change anymore. What is
    I fixed a problem with my Schwinn Elliptical 430 resistance level not working. When I would change the level anywhere from 1-16, I could hear the motor turning, but there was no change in resistance. If you hear the motor moving, then try this:
    Using a Phillips screwdriver, remove all the screws on the left side of the large plastic cover (left side if you are standing on the machine). When all screws are removed, you can pull the plastic cover off, and move it towards the back of the machine without having to disconnect any of the metal bars. (The bottom two screws are a little tricky to get off. Hold the housing in place, don't let it sag, in order to get them out.
    Look inside the unit and find the magnet, which is a rounded, brake-show like piece that is close to the flywheel, on the top half of the unit. There's a cable from the motor that goes upward and is attached to the magnet housing.
    If you try to adjust the resistance level now, you should see cable move up. This is supposed to allow the magnet to move closer to the flywheel and increase resistance. In my case, the magnet was stuck and wouldn't move upwards. When I gave the magnet a little push with a screwdriver, it popped up to where it should be.
    To solve this issue, you will need two wrenches. You must go to the opposite end of the magnet, towards the front of the machine, and you will see it's connected with a nut & bolt. Using a couple wrenches, hold the bolt, and loosen the nut about 1/4 turn.
    This should lessen the pressure on the magnet housing and allow it to move freely and not bind. Reassemble everything. Lie the elliptical down on it's side to allow the screws to fall into the holes easier.
    Once it's all back together, you should find that the resistance level works again!
    Sep 23, 2009 | Schwinn 430 Elliptical Trainer
    May 03, 2009 | Ironman Fitness Achiever Elliptical...
    Exercise & Fitness Logo
    37 people viewed this question
    Top Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
