Question about Covercraft Personal Watercraft Cover - YAMAHA Wave Runner XLT 1200 (2001-05), XLT 800 (2002-04) - w/ rear tie down opening
How many hours will a xlt 1200 rebuild last for
I am wondering how long the life cycle of a XLT1200 is after a motor rebuild?
    Top Expert:
  • Covercraft Master
  • 51,342 Answers
If a rebuild was done to new specs and there were no short cuts or reused old bits because they looked good and were in side limits I would expect around 75% of the new time up to when the rebuild was necessary i9f not more. A rebuild if done properly should last as long as the original motor but unfortunately the cost causes most people to take shot cuts and use after market parts so the useful life will be less
Posted on Aug 07, 2013
1993 waverunner bogging down on take off. New rebuilt carb, will low oil level cause this? Is there a low level switch /?
Only of you have ran the engine out of oil...Sounds like the carbs may not be set correctly.. .Did a professional do the rebuild?..What exactly was "rebuilt".. were any parts replaced?
Sounds like the low speed (pilot jets/air screw passages may not be clean as they need to be??)
Please check the compression on each cylinder..remove the spark plugs... hold the throttle (carbs) wide open when you check this.. spin the motor for 5-8 seconds... you should get 120psi. minimum..(and less than 10psi difference).. if less, it might be time to actually rebuild the top end..(new pistons/rings/hone cyl.).. only bore it if absolutely necessary.. get it measured..
There are only 3 parts in a two-cycle carb that ever need to be replaced,,(unless they are actually broken) The needle and seat assy., the jet needle and the needle jet. ..see pic... parts # 41 = needle and seat assy. #6 = jet needle, #37 = needle jet.
The needle and seat regulate the flow of gas into the carb as the floats rise and fall..,, if they are damaged or leaking the carb will overflow with gas., the needle jet is a orifice with a specific size..The jet needle has a specific size, taper, and length..== The jet needle and needle jet work in unison to regulate the flow of gas from right off idle all the way to WFO..the needle jet/jet needle WILL wear over time causing the fuel/air mixture to become richer and richer and start fouling spark plugs..(this is more pronounced on 4-cycle ATV's)...
I hope this has shed some light on your carb situation...
Good luck...
exploded view of mikuni carb Google Search
Jul 10, 2017 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Hi How long should the service take when checking shims ? Sorry Triumph Explorer 1200 (2014)
Hi, Mark all depends on the mileage but a 20,000 service takes which includes checking and adjusting valve clearance takes about 7 hours for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Triumph 2012 2015 Tiger Explorer 1200 Service Repair Manual Download... $18
Hermys Tire Cycle Inc 2013 Triumph Tiger Explorer Genuine Motorcycle Parts...
Triumph Tiger Explorer Owner Handbook Manual
Triumph Tiger Explorer 2014
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 05, 2017 | 2013 Triumph Tiger Explorer
Will an electric motor with more horsepower and more rpm hurt a compressor pump?
Electric motors seem to turn around 1125 rpm or 3600 rpm. The pulley size on the motor and pump must be adjusted to achieve the desired result without overheating /loading the motor. I have seen pumps turning from 800 to 1200 rpm using different pulley size on motor, motor hp and motor rpm. Some brands will turn same pump from 1200 to 3600 rpm depending on if was electric or gas motor. This will certainly shorten the life of the pump but will most likely work. Most turn an average of 1200 rpm for good balance of long life and good supply of air. Pump rpm is usually limited to the power of the motor. Cost effective match of 1.5 hp motor will turn pump about 1000 - 1200 rpm for about 5cfm. Rol Air 2hp motor turns 2 cyl pump about 1100 rpm for 10 cfm. Good luck
Mar 17, 2015 | Campbell Hausfeld Tank Air Compressor, 1...
Zanussi progress 1200
check the filter for blockages
May 01, 2014 | Washing Machines
Relay replace starter
if its xlt 1200 its inside the big black electric box at rear of engine ! unbolt it and remove the back cover !
Jan 10, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
High idle 1997 gp1200
obviously your fuelling isn't set up correctly
Jul 13, 2012 | Yamaha 98 Gp 1200 Air Box Intake Mount...
I want to find out the life expectancy of the bulb (lamp) that comes with the Optoma projector model VDDVGG
We tracked it when we first bought ours. The lamps go anywhere from 800 to 1200 hours. First, I don't think the manufacturing process is very consistent so they very a lot. Also, it seems the more you turn them on/off the shorter the life. If you use for longer periods, then they last more hours.
You might be able to get 2000 hours out of one if you just leave it on without turning it off but that is a waste too.
-Mark
May 18, 2011 | Audio Players & Recorders
2002 yamaha 1200 vmax 4 bbl carb fouling plugs
Hi, Jamie12r and the usual suspects are:
1. Dirty air filter.
2. Fuel mixture too rich or enrichner/choke left out too long.
3. Faulty spark plug.
4. Incorrect spark plug heat range for the engine type or service.
5. Piston rings badly worn or broken.
6. Valve guides are badly worn and/or seals worn, crushed or have come off the valve guide and are pumping oil through it.
7. Spark plug cable weak or leaking check for spark jump in the dark.
8. Faulty ignition coil.
9. Low RPM nonaggressive riding style.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Vmax fouling sparks plugs
Thread What Will XLT1200 Behave Like Fouled Spark Plugs
Yamaha VMX12H Supplementary Service Manual
OEM parts for Yamaha
Yamaha VMAX VMX12W1 Owner Manual
May 13, 2010 | 2002 Yamaha V-Max
Covercraft Personal Watercraft Cover - YAMAHA Wave Runner XLT 1200 (2001-05), XLT 800 (2002-04) - w/ rear tie down opening Logo
135 people viewed this question
Top Covercraft Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Covercraft Boating Expert? Answer questions, earn points and help others
