Question about Thermor 266BC Wireless wind chill & humidex
Bios wind sensor 266BC
Indoor/outdoor temp indoor and humidity, wind chill
Temperature in/out 911711; changed batteries on bothe indoor and outdoor units. Outdoor temp not registering on indoor unit.
  • Remove all batteries
  • Install batteries in outdoor unit and allow it to initialize and begin sending data.
  • Install batteries in indoor unit. You should see outdoor temperature displayed
If not, either unit or both may be defective
Aug 07, 2017 | Measuring Tools & Sensors
I have the weather channel indoor outdoor thermometor and the outdoor temp and humidity are not showing up on my wall reader
With mine, this indicates that the battery needs replacing on the INDOOR unit. For some reason they don't pick up the signal from the transmitter. I use batteries 3 to 1, indoor to outdoor.
Feb 23, 2017 | Weather Channel Measuring Tools & Sensors
How to set up taylor `model 1731
  • Indoor (32°-122°F/0°-50°C) and outdoor (-4°-140°F/-20°-60°C) temperatures. Lower outdoor temperatures achievable with lithium batteries; Indoor and outdoor humidity. Includes temperature and humidity trend indicators; Daily min/max recall for temperature and humidity. Features a calendar and clock with alarm; The wireless remote sensor transmits up to 200 ft. The base station and wireless remote require 2 AAA batteries each, not include. If you want essay related topic you can go for custom essay writing service will get better result.
New Generation Custom Essay Writing Service with Intelligence EssayCaptains
Feb 06, 2017 | Taylor Health & Beauty
Outdoor temperature reading shows -40 with wind chill -62. Outdoor temp is in fact +45.
We would recommend a hard reset of your Weather Station. Please verify that you are using a good-quality, standard alkaline battery such as Energizer or Rayovac, and then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall battery into the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Mar 17, 2015 | Chaney Measuring Tools & Sensors
Springfield precise temp in out thermometer 91756
Return it to the manufacturer for warranty repair/replacement
Jul 23, 2014 | Taylor 91756 Wireless Thermometer With...
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
Charging an air conditioning system
R22 systems should run a 68# to 70# suction pressue. If you look at the suction guage at 68# that is a 40 deg evaporator coil temp.
Nov 18, 2012 | Ruud Central System Air Conditioner
PANASONIC CASSETTE AIRCONDITIONING ERROR CODE NO :- F27-02
f27- indoor outdoor unit disconnected. Check the power output of indoor and input of outdoor.
If no power you have to check indoor room temp sensor through which thermostat send command to outdoor unit. If your sensor is good, you have to repair/replace your PCB
Dec 14, 2010 | Heating & Cooling
BIOS Digital Wireless Thermometer 312BC SETUP INSTRUCTIONS
I have a BIOS wireless indoor/outdoor thermometer. The indoor base unit doesn't display the outdoor temperature - it is blank - however the other temperatures - humidity, indoor temp, etc., are displayed, What is the problem? We have misplaced the manual so we don't know what to do.
Aug 28, 2010 | Measuring Tools & Sensors
Temp
Before an evaporation cooler will feel "cool" there has to be a greater difference in the outdoor and indoor temps and/or humidity. If the humidity is high and the temp cool < 80'f The "cool" wont feel cool because there is not much evaporation taking place.
Now if the temp goes to 90 or the humidity goes down under say 40% the cooling effect "feeling cool" will change and be more like its cooling. Part because of the difference in the temperature but also because the air can hold more humidity and it is pulling moisture off your skin.
When you talk about "feel" it is rather suggestive and always different for different people.
Aug 04, 2008 | Mastercool 67680 Evaporative Cooler Air...
Thermor 266BC Wireless wind chill & humidex Logo
217 people viewed this question
Top Thermor Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Thermor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
