Question about Whirlpool Duet GHW9150P Front Load Washer
F H displayed on front
I have a whirlpool duet washer and FH is displayed on the front. Does anyone know what that means?
  • 640 Answers
It means no water is entering unit,,,check hot and cold hose,,,clean your inlet screen ..look for a kink in your hoses,,also check and make sure water is leaving unit,,if water isnt leave than ,,unit will not let water in ,,in case of an overfill..if you need help cleaning pump filter let me know...onthejob
Posted on Jan 27, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
FH SIGNAL MEANS ......... WHAT IS THE USE OF FH SIGNAL........ AND APPLICATIONS
The error code FH means no water is detected entering the machine which can be due to a faulty flow meter not registering the correct amount of water that has passed through it or the pressure is not tripping from the empty position to the full position when the correct water level has been reached. Your machine is definitely made by Whirlpool like other Kenmore and Maytag washing machine so they are basically the same and troubleshooting is then the same. The link below contains the detailed troubleshooting of this error code for a Whirlpool Duet and should be applicable to your machine.
Error Code FH on Whirlpool-made Front-Load Washers
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
Front load washer is saying FH... what does this mean?
FH no water decected enter machine to clear press pause/cancel/pause/cancel
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer keeps reading FH during the wash cycle
it means it can't detect water or that the pressure switch trip is not found--press pause/cancel twice to clear the display
Sep 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer duet
The FH means water tap closed. If you were happy with using cold only you could get a Y-piece connector and join both the red and blue inlet hose to the cold tap.
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer trouble
fh means no water coming into washer. remove cold water line from back of washer and see if the screen in the valve is clogged. if so, remove screen and clean it, if not replaced water valve
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
140 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
