Question about Audiovox Voyager Aom-7694 7" Flat Panel Lcd Observation Monitor
Aom7694 screen swirl - Audiovox Voyager Aom-7694 7" Flat Panel Lcd Observation Monitor
Have a code P1138 on 2003 Toyota Tundra - how do I fix ?
Swirl Control Valve Control System Performance Repair Importance Level: 3/3 Repair Difficulty Level: 2/3 Possible causes - Faulty Swirl Control Valve Control Position Sensor - Swirl Control Valve Control Position Sensor harness is open or shorted - Swirl Control Valve Control Position Sensor circuit poor electrical connection - Faulty Swirl Control Valve What does this mean? Possible symptoms - Engine Light ON (or Service Engine Soon Warning Light) P1138 Description While idling and during low engine coolant temperature, the swirl control valve closes, Thus the velocity of the air in the intake passage increases, promoting the vaporization of the fuel and producing a swirl in the combustion chamber. Because of this operation, this system tends to increase the burning speed of the gas mixture, improve fuel consumption, and increase the stability in running conditions. Also, except when idling and during low engine coolant temperature, this system opens the swirl control valve. In this condition, this system tends to increase power by improving intake efficiency via reduction of intake flow resistance, intake flow. The swirl control valve is operated by the Engine Control Module (ECM).
Read more: http://www.autocodes.com/p1138.html
Oct 02, 2016 | 2003 Toyota Tundra
Sony tablet SGPT111GB/S switches on and then shows swirling all the time and will not start with connection
my sony model sgpt111gbs try to start and stack at the wave thing that bring after showing SONY, so what do i do?
Apr 09, 2013 | Tablets & eReaders
P1109 error code
DTC P1109 Secondary Port Throttle System
Did you get a subcode?
-0F Swirl Actuator Malfunction
-08 Swirl Actuator Supply Voltage Range/Performance
-05 Swirl Actuator Feedback Circuit High Voltage
-02 Swirl Actuator Feedback Circuit Low Voltage
-29 Swirl Actuator Feedback Signal Malfunction
-28 Swirl Actuator Feedback Signal Malfunction
-21 Swirl Actuator Feedback Signal Range/Performance
-54 Swirl Actuator Feedback Powerstage High Temperature
Oct 29, 2010 | 2004 Saab 9-3
Hitachi 50v500 reddish cloudy swirl sweeps across
motherboard has gone out cost is about $700 including labor i just was quoted that price mine is doing the same
Jan 31, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Ps3 start up screen displaying swirl and then nothing
your lens is out buy a new one and follow the you tube instructions for replacement unless you have a warranty but there is no guarantee ;that you will get the same machine back
Jan 31, 2009 | Sony Playstation 3 (PS3) Console
LG VU SCREEN PROBLEMS
you might have pushed down 2 hard on the screen if it is purple then thats the case
Dec 19, 2008 | LG Vu CU920 Cellular Phone
Sony Cyber-shot DSC-T10 - Silver (7.2MP, 3x Optical Zoom) 2.5" LCD. When the camera is turned on the screen is white. There is also a black swirl through the centre of the screen, the shadow of this...
I have lost my battery cover for my Sony Cybershot DSC-T10. IF your camera is water damaged and you want to sell it. Let me know, I could use the battery cover that slides and "clicks" into place.
Thx
Mark
512 784-6771
Sep 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Swirl Valve
I have been working on a 96 nissan truck for three years for an evap code and swirl control , I finally just made sure the swirl control solenoid operated properly then disconnected the vacuum hose from the swirl control actuator and plugged it . code fixed.been driving 3 months, no code
Aug 07, 2008 | 1996 Nissan Pickup
Screen flicker, color swirls
Mine does the same has done since new, It was sent back and when returned it still does the same. If i tap the top of the screen it comes right again for about 10 miniuts
Jan 22, 2007 | Neovo F-417 17" LCD Monitor
Audiovox Voyager Aom-7694 7" Flat Panel Lcd Observation Monitor Logo
Top Audiovox Home Security Experts
Lawrence Oravetz
Are you an Audiovox Home Security Expert? Answer questions, earn points and help others
