Question about Philips Televison & Video
How do I reset tuner for Phillips 32HF7965D/27
TV powers on. Menu offered is not the full menu. Can't get to "language" for setup.
  • peter7383 May 16, 2015
    It is in hotel mode, you need a special remote
dsacco86
  • 1077 Answers
SOURCE: My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
Posted on May 27, 2009
SOURCE: Vizio LCD DTV 32 inch. Model L32. I can't 'scan'
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
Posted on Jun 08, 2009
dsacco86
  • 1077 Answers
SOURCE: phillips plasma tv. Settings menu pops up all the
Philips.com should have a software upgrade for your TV to fix the problem. This is a common problem with Philips TVs and they have made upgrade software to address the problem.
Go to the Philips web site and all the procedures for download to your TV will be there. The only thing you will need to this is a USB memory stick. Download should be FREE.
Posted on Aug 03, 2009
57 varieties
  • 1653 Answers
SOURCE: I bought a 32LC5DC Lg
The only thing that would cause this is a lock!
If you ever forget your password, key in ‘7’, ‘7’, ‘7’, ‘7’
on the remote control.
If unlocking does not free up the unit menu then the unit has most likely had a software upgrade at some point to disable these functions permanently. This is normal hotel based systems in order to prevent them being used if they are stolen. In this case you will have to contact LG directly with Model no and Serial No details to get them to assist you.
Posted on Oct 01, 2009
  • 6 Answers
SOURCE: SAMSUNG LE32R73BDX/XEU TV
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Posted on Oct 05, 2009
I wanna change the language of my Sony Bravia KDL40V2500 from japanese to english and i can't do it. How can i?
Most language options on electronics are found under "Settings"
Switch on
Menu
Settings
Preference
Language
Sep 22, 2015 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How do i reset audio language on tv?
Go to setup menu on the TV using the remote and select English from the language option and press OK. You may need to browse through the setup menu to locate the language option.
Jun 26, 2013 | Westinghouse Televison & Video
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
RCA F27442 - Cable showing up "snowy". Found tv outside, so maybe it's shot, but wanna chk just in case. Anything other than what 'Menu' offers can help - something physically inside...
Real common problem with RCA, bad connections in tuner/ if module, Solder tuner and if module and leave shield off tuner and solder main grounds around tuner.
Aug 15, 2011 | RCA F27442 27" TV
Change from spanish to english
Hello
The Plug In Menu comes up automatically when you first turn on the TV after plugging it in. The
Plug In Menu helps you to get your TV ready to use by letting you set your preferences for:
• The Language in which you want the onscreen menus to appear,
• The Auto Tuner Setup of which channels you wish to receive,
• Setting the TV's clock to the correct time so your timer functions will work properly.
Descriptions of each of the Plug In Menu features appear on this page and the next.We recommend
you complete the Plug In Menu setup first so your TV is set up just the way you want,
right away.
Introduction
Auto Tuner Setup
Language
You can choose to view your onscreen menus in three languages: English (ENG.), French
(FRAN.), or Spanish (ESP.).
Press the MENU button
Press UP or DOWN To LANGUAGE
Press RIGHT or LEFT button to choose a language
You will not need to press the MENU button to enter this screen from the Plug In Menu.
OK
Dec 26, 2010 | JVC AV-27850 27" TV
I moved tv now it want go past channel 13
No problem. Go into menu to channel or tuner setup.. When it was unplugged the tuner reset to air and needs to be changed to cable and then auto program the channels..
Oct 17, 2010 | Panasonic CT-27D12D 27" TV
Can't Program Channels In Philips 32HF7544D/27 LCD TV
Firmware update is necessary. It is corrupted.
Jan 22, 2009 | Televison & Video
Lumix fx 500
Vincenzo, ti scrivo in italiano, cosi non usiamo traduttore, a quanto dicono i manuali la macchina dovrebbe avere opzione linguaggio giu nel menu, prova a ricontrollare.
Riporto la risposta del mio ultimo commento :
"Guarda che se vai giu nel setup menu, quello con la chiave dameccanico, dovresti trovare il menu Language, che forse nella tuacamera e' in giapponese, da quanto ho capito.
Qui c'e il manuale in inglese piu completo.
A pagina 23 inizia a spigare il setup menu, a pagina 27 c'e' language.
Secondo il manuale le voci del setup menu iniziano con l'orologio e sono:
  1. Clock
  2. World time
  3. Monitor
  4. LCD
  5. beep
  6. volume
  7. guideline
  8. histiogram
  9. travel date
  10. economy
  11. auto review
  12. no reset
  13. reset
  14. usb mode
  15. Video out
  16. Tv aspect
  17. m/ft
  18. touch guide
  19. format
  20. Calibration
  21. Language
  22. Demo mode
al posto 21 c'e la faccina con qualcosa in giapponese.
Se non la trovi fammelo sapere."
Se nel modello giapponese non c'e' l'opzione linguaggio, allora sei nei guai, perche panasonic non ha ancora distribuito un update del firmware per questo modello, si trovano solo modelli precedenti.
Per quanto ho visto il firmware non e' disponibile online.
Puoi provare a richiederlo a panasonic, qui c'e la pagina dei contatti.
Ricontrolla e vedi se trovi il menu linguaggio, e' strano che non sia presente.
Questo e' il simbolo della faccina che indica il menu linguaggio: bba5910.gif
Oct 27, 2008 | Panasonic Lumix DMC-FX500 Digital Camera
RCA 27V550T 27" TV
Problem fixed. I unplugged the TV for 20+ seconds, then before plugging it back in, I shorted ac plug prongs together with a metal key to ensure complete discharge. Plugged TV back in and used procedure to reset password WITH ONE CHANGE TO THE PROCEDURE.
With TV turned OFF press and hold <CLEAR> button on the remote while pressing <VOLUME DOWN> button on the TV, hold until TV turns on. When the menu appears DO NOT RESET THE PARENTAL CONTROL CODE as the user guide instructs. When my menu appeared it was in the SETUP screen on the LANGUAGE setting. It was set to SPANISH, using the remote I navigated to ENGLISH. Then using the remote I navigated up to GO BACK. Then I navigated to EXIT and hit <OK> button on the remote. All was back to normal.
Jan 10, 2008 | RCA 27V550T 27" TV
32" Sony Wega -- initial set-up menu constantly on
Came across this because I was having the same problem. I was getting the menu immediately. It started with the remotes not working with the TV, so I unplugged it. Afterwards, the initial setup appeared, but couldn't complete. I don't have anything connected to the tuner, everything is on video inputs. Don't know why it wouldn't complete, it would get 20-40 channels into it, and stop, and the "initial setup screen" appeared. I ended up turning off all peripherals, waited about 10 minutes, then running the setup. it finally completed the scan of the tuner channels, and has not appeared since. Perhaps just an accidental solution, but hopefully something in there helps.
Jul 26, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
190 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
