Question about Bobrick 262 C-Fold Paper Towel Dispenser, Each
Install towels (c-fold) into a Crown dispenser
  • 52 Answers
Use key open cover install 2 pks of c fold with cfold facing down and walla dispenser works
Posted on Jan 28, 2009
From which store i can get better Towel roll dispensers and Tissue roll dispensers in California?
Lollicupstore from you will get better Towel roll and Tissue roll dispensers in California.
You may visit - http://www.lollicupstore.com/
Or
Contact here:
Lollicup USA Inc.
6185 Kimball Ave, Chino, CA 91708
Phone: (626) 965-8882 or (800) 857-1988
Fax: (626) 965-8729
Jun 11, 2016 | Office Equipment & Supplies
Our Whilrpool Imperial Series ED22LF side-by-side refrigerator has developed a leak (drip) from the in-door water dispenser. The refrigerator is about 10 years old. Can this leak be fixed? If so, can you...
Have you tried to change the remove the water filter? (It needs to be changed every 6-months.)
I find that when I change the water filter on my fridge, it takes a few times using the water dispenser on the door before it totally stops running. But it does stop. In the interim, place a couple folded paper towels under the spigot to catch overflow. When you see that the towels are dry, you are in business.
Put a post-it note in your fridge with the date of the last time you changed your water filter, the model and serial number of our fridge. When its time to replace, either bring the post-it to the applicance store's parts counter and/or input the data into your online order. Change out every six months.
Secondly, if the above does not apply/work, then go to the yellow pages in your area and look up Appliances...small applicance repairs and parts. Contact the vendor and pose your question about parts, repairs degree of difficulty to repair ( like your spouse).
Jan 27, 2011 | Refrigerators
How do I remove the interior window handles. This
the inner handles are held on by a spring clip that captures the shaft of the window regulator to the handle.
most parts houses have a tool to remove the clip without damage to the door panel or handle.
Jul 27, 2010 | 1991 Oldsmobile Cutlass Ciera
Hp photosmart 7350-cannor print from emails or any
Your printhead is either clogged or not working. There should be a self cleaning program built in to the printer. Run this 4 or 5 times. If the unit still doesn't print you can either clean it yourself with Q-tips and isopropyl alcohol, or take it to your local HP printer repair center. If you printer is still under warranty I would advised having them check it.
Jul 15, 2009 | HP PhotoSmart 7350 InkJet Printer
Problem in color printing
I would suggest removing the ink cartridge (careful because ink is permanent and if it gets on your hands it's difficult if not impossible to get off) wear gloves if you have them. Fold up a paper towel several times, soak it in a shallow pan of water and set the cartridge on the paper towel for a couple of minutes. You want to set the copper looking thing on the paper towel just for a couple minutes. Then remove it and place it on a dry paper towel ,that you have folded up a few times don't wipe it blot it with the dry paper towel. When it is dry set it on another folded up paper towel and press down slightly and you should see three distinct colors on the paper towel. Of course it is the color cartridge you will be doing this too. If you don't see three distinct colors appear try the procedure again and if it doesn't work after the second time I would return the cartridge to wherever you purchased it. Good Luck.
Jun 20, 2009 | HP Photosmart 2610 All-In-One InkJet...
Floor smeared after applying plasplugs polish on ceramic
Place a folded towel under buffer and make the removal process as follows: apply way. buff with towel rotating fold to keep build up off, then switch to a clean towel and hit a final time. you should be able to apply more wax and buff off again with towel and solve current problem.
Jun 05, 2009 | Mountain 7" Angle Air Polisher
CAN NOT PRINT COLOR -PRINTS PINK STRIPES
Take some paper towels, fold them in half, spray them with alcohol FREE glass cleaner and set your color cartrige on the paper towels and let them soak for thirty minutes or so. DO NOT USE ALCOHOL it sets the ink. also clean the thin plastic strip in the back of the print heads this is the encoder strip and it tells the print heads when to dispense if this is dirty from overspray it will affect your print quality. Use q tips and the same alcohol free window cleaner.
Jun 04, 2009 | HP Officejet 9110 All-In-One InkJet...
Color ink want print after installing new cartridge
Take out the cartridge first get a couple paper towels fold them put about a teaspoonful of water in the center to get a wet spot then place the cartridge on the paper towels. the ink will soak out, use it to get the cartridge working may take a few tries, but it works. the place in printer and run a cleaning. secret is never let them dry-out and refill before it runs out.
Mar 26, 2009 | Lexmark Inkjet Z517 Photo Printer
Whirlpool GD5SHAXKQ00 Ice/Water dispenser
Hey,
It's pretty easy to remove by yourself. DO NOT force it or it will probably break. Nice and easy will do it. You'll need a flat headed screw-driver and a towel.
-There are 4 retaining tabs. 2 on top and 2 on the bottom.
-Remove the drip tray in the dispenser area
-Start with the bottom. Before starting, look underneath the surround (yes--bend down, stoop or lie on the floor -- your preference) You will see 2 thin slots. That's exactly where the tabs are. Do one tab at a time.
-Place the folded towel under the surround at the same time you are placing the screwdriver tip gently at the slot---DON'T apply pressure to the screw-driver yet.
(The towel will protect the paint and by being folded will provide a slight leverage for the screwdriver) Hold the towel against the door with the same hand you're holding the screw-driver with. If you can't....then cry for help.
-With your free hand press down firmly on the lower part of the surround (where you removed drip tray from) ...at the same time GENTLY pry with the screw-driver.
It shout pop out pretty easily.
-Repeat for the other bottom tab.
-For the top tabs, lift the entire surround up and then out.
-Remove the wiring harness and VOILA!!!
-Show off to your wife.
Dec 28, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Bobrick 262 C-Fold Paper Towel Dispenser, Each Logo
152 people viewed this question
Top Bobrick Home Experts
john h
Tom Chichester
Are you a Bobrick Home Expert? Answer questions, earn points and help others
