I am not getting sound to speakers from my luxman r-115 receiver
2 Suggested Answers
SOURCE: Luxman R-115 NEED REMOTE CODES FOR COMCAST ON DEMAND REMOTE
I tried Logitech Harmony for my Luxman RX-103 and Luxman LX-104. Logitech does not support these even tho their list says it does. I spent more than one hour with their live tec on the phone.
Mansour Zianour
Posted on Sep 03, 2010
How do I fix my audio/video receiver that has no sound coming out of it?
If your unit has a speaker protection mode (5-8 second delay when 1st turned on) defective speakers and/or speaker wiring may be causing the protection circuit to do its job...protect the speakers. Disconnect all speakers and test HK in all modes (tuner, CD, DVD, etc.) using headphones. If you still cannot hear audio then it's time for a shop repair. Although I recommend factory authorized service whenever possible, a "local" shop that is certified by other well-known brands may be an option. If Yamaha, Onkyo or Luxman certified your local repair shop then it's a sure bet that they can properly repair HK's no longer under warranty.
Mar 22, 2015 | Harman Kardon AVR 340 Receiver
How do I fix a Luxman stereo receiver that has blown channel to one speaker
I myself would just get another stereo, and not tap wires together
Jan 25, 2015 | Cars & Trucks
I bought a used Luxman Stereo Receiver r113 and now my one Cerwin Vega speaker is crackling and distorted after 10 minutes of playing for the first time
As it's a stereo receiver and you specify one CV speaker, hook the speaker to the other side of the receiver and see if it still has the same problem. If so, hook it to any other audio source you may have. If it has a problem on only one side of the receiver, the receiver has a blown channel. If the speaker distorts on both sides of the receiver and on a separate audio source, the speaker is blown.
I have a 22 year old Luxman receiver. The left speakers periodically turn off, but seem to recover if I really turn up the receiver volume. I did just reconnect the speaker wires in an attempt to fix the...
To be honest it sounds as though your volume control needs a clean, try to find some switch cleaner (servisol or similar) remove the casing and spray into the volume control from behind the face plate as apposed to from the front. Rotate the volume all the way back and forth several times to clean the tracks, I have used deodorant in the past to achieve the same result but as this will leave a residue, probably not recommended as a permanent fix. Obviously do these actions with the amp switched off, otherwise you will at the very least annoy your neighbours with the loud volume.
Hope this is helpful.
May 06, 2011 | Audio Players & Recorders
I want to hook my bose 901 VI along with EQ to my Luxman R117 Receiver and also run other speakers from the same receiver. Is this possible?
If you are using the Bose Equalizer to optimize the sound of the 901s by going through either a tape loop or a pre-out/main-in loop, then the only way to do this without also equalizing the sound sent to the second set of speakers is to manufacture a "zone-2" output from the Luxman.
You'd probably need to split the send from the Luxman's pre-out before the EQ and send it to a second power amplifier for the second pair of speakers (if you want the Luxman's volume knob to control both speaker sets) or from a tape level output (if you wanted independent volume controls for the two speaker sets.
The whole EQ thing made 901s difficult to use on vintage equipment with only one "zone" audio outputs. Unless you want to use the Bose EQ on the second set, too, you can't do it satisfactorily without adding another stereo amplifier. But, go ahead and try it, you might find that you actually like the odd EQ that the 901s EQ gives to the second pair!
If it were my decision, I probably would not do it without a second amp, but it's all about what you like, my opinions really don't matter in your house, do they?
Have fun
Jul 24, 2010 | Bose 901 VI Main / Stereo Speaker
Try a Harmony by logitech. They will control every feature of every piece of product that you have. Prices start around 50 on ebay. The software for programming is excellent and very user friendly. Their tech support speaks to you in understandable language if you have a problem. I've probably programmed a thousand or so to date and they are very reliable. The only issue I have with them is Don't Drop Them on a hard surface, the LCD's are pretty fragile. If you have young kids, keep them away from it!. With a little tweaking in the program, you can have a very reliable and effective remote for very little $. If you get one and have any questions on programming, post a comment and I'm positive I can help. Hope this helps
Jun 22, 2009 | Audio Players & Recorders
Luxman Digit synthesized stereo Receiver AM/FM & Phono not work'g
The problem is still there, but I am expecting HELP fir free.
May 11, 2009 | Car Audio & Video
61 people viewed this question
 Grubhead
Grubhead
