Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
The drive belt as come off
Having removed the 2 rear screws istill cannot remove thetop so i can refit the belt
  • dnldnt Mar 23, 2009
    same problem here, the belt was coming off, fixed back, but it's coming off after few min., everytime i put it back, it's coming out, what a ****! any ideeas pls?
  • Hotpoint Master
  • 3,463 Answers
It is virtually impossible to fit belt from top on this washer dryer. as there is no room to get your hands in.
The easiest way to do it, is to remove the rear panel, and fit it from the back.
You will find it easy to do it this way.
Plz rate my solution.
Thanks.
Posted on Jan 27, 2009
  • Barry Coates
    Barry Coates Jan 27, 2009
    Should you need to remove the top, make sure that there is not 3 screws fitted, having removed the screws, smartly push the top to the rear of the m/c. they sometimes stick under the front console panel.
Removing ASUS CG8350 cd drive from a desktop computer
Removing a cd drive isn't difficult and takes just a few minutes.
1. Remove the side panels (screws are at rear of casing)
2.Remove the screws on each side of the cd drive - the screws hold it into its slot.
3. Remove the power cable and data cable by gently pulling on the connector that fits the rear of the cd drive. You may have to hold the cd drive and 'rock' the connectors slightly.
Take note of which cable goes where. depending on whether it is ide, you may have a color coded power cable. Connectors only fit to the cd drive in one position. Make sure you know which way to refit them.
Insert your new cd/dvd drive and simply reconnect the cables. replace the holding screws and then refit the side panels. It's a straightforward job that only takes a few minutes.
Apr 07, 2013 | ASUS CG8350-06 Desktop Core i7 3.4GHz 8GB...
Kia sedona instructions to replace serpintene belt
Hi, Here is the procedure for a 2002 KIA Sedona 2.9, Engine code KJ. I I can not guarantee the followingprocedure is exactly the same as your car.
Warnings and recommendations Unless otherwise advised by the manufacturer, the following procedures are recommended: Always fit a new timing belt after removal Check the tensioner and idler pulleys; renew if necessary Never turn the engine in the direction opposite to that of normal operation Check the belt(s) for cracks, fraying, wear and oil contamination Note: The engine must be cold before timing belt adjustment Note: Avoid bending, torsion or traction General Before disconnecting the battery cable, check the audio system security code kj_t_dba_uk_6.jpg
Always check the timing marks before timing belt removal Removal Disconnect the battery Remove the radiator upper hose Remove the fuel filter unit Note: Do not disconnect the hoses carniv_j3tci_t_dba_uk_3.gif
Remove the bracket Remove the right front wheel Remove the air-conditioning drive belt Remove the ancillary drive belt Remove the ancillary drive belt tensioner Remove the coolant pump pulley Remove the crankshaft pulley Remove the timing cover(s) kj_t_dba_uk_6.jpg
Remove the tensioner Remove the timing belt Check the gearwheels, tensioner and idler pulley(s) for damage and wear Renew if necessary Installation kj_t_dba_uk_6.jpg
Align the marks on the tensioner Tighten the tensioner (23.5 Nm) Rotate the engine 2 rotations by hand kj_t_dba_uk_6.jpg
Check the tensioner Repeat the procedure if required Refit the timing covers Refit the crankshaft pulley (373 - 392 Nm) Refit the coolant pump pulley (17.6 - 28.4 Nm) Fit the ancillary drive belt tensioner Fit the ancillary drive belt Refit the air-conditioning drive belt Refit the front right wheel (88 - 108) kj_t_dba_uk_4.gif
Fit the bracket (36.2 - 53.9 Nm) Refit the engine mount carniv_j3tci_t_dba_uk_3.gif
Refit the fuel filter unit Refit the radiator hose(s) Refill the cooling system Check for leaks Reconnect the battery earth cable Torque settings Tensioner: (23.5 Nm) Timing covers (6.9 - 9.8 Nm) Coolant pump pulley: (17.6 - 28.4 Nm) Special tools Special tools are not required
Jan 06, 2013 | 2004 Kia Sedona
Door springs on Fisher & Paykel 920 dishwasher not working at all .How can they be replaced?
Hi - heres the instructions for you - have fun.....
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
Aug 10, 2011 | Fisher and Paykel 24 in. DS603H SS...
The drum of my Zanussi TC7103 was making a knocking noise and has now also stopped spinning i have removed the side and the drive belt is fine. The belt loops the drum and then goes round a black plastic...
yes you can replace the belt tentioner . disconnect capacitor wires remove the spring off the motor slip the belt behind the pulley so the motor can move round. remove the rear fan cover ( screw and retaining clips) this to allow pulley to be slid off. fit new tentioner pulley and pull belt in front of pulley refit spring to motor down to cabinet.reconnect capacitor. refit fan cover.125 01 25-20/8 is part no for one of 12 variations of this model use the product no to get the right part 916xxxxxx
Aug 26, 2010 | Zanussi Dryers
How to put on v belt sportcity 125 aprilia
Put the bike on center stand.
Remove the outer drive belt casing, you will need to remove the normal stand to get at the bolts. A light tap to the side and it will come off.
If the drive belt is snapped, pull it out and make sure nothing is inside.
Loosen the rear pulley, and move it towards the front gear. Slip over the new drive belt and tighten the rear pulley back up. You should aim for around 2-3mm of deflection in the belt. refit the casing and the stand. Start her up and off you go :)
Vote for me please if this helps you, thanks.
Jul 06, 2010 | 2007 Aprilia Sportcity 125
Bosch classixx 1200 fills, drains, but won't wash ?
This a classic example of worn brushes in the motor.
To check , remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws that secure motor, and lever motor back with a screwdriver or similar.
Keep hold of the motor as you lever it back.
You will find the brushes at the terminal end of the motor, replace if less than 4=5 mm in length.
Refit motor belt and motor plug.Test. before you refit panel
Thanks.
Jan 12, 2009 | Bosch Washing Machines
Changing bushes on bosch classixx1200
To change brushes in Bosch motor.
Remove rear panel of washer, undo 2 screws that secure motor at front end, remove motor plug, lever motor back with a screwdriver or similar, and remove motor retaining a hold on it,\ so as not to drop it .
Replace brushes fitted at rear end of notor.
Refit motor and belt.
Thanks.
Jan 08, 2009 | Bosch WFK 2401
How to replace motor brushes
Revove back plate & take belt off.Motor is held by 2 screws. unplug wiring block and earth wire then remove motor. on rear of motor are 2 plastic housings which hold brushes. make sure new ones sit correctly on armature then refit motor.
Nov 15, 2008 | Hoover Washing Machines
Fitting new brushes on a hotpoint washing machine
Remove lower rear panel.remove drive belt, undo screws that secure motor. unplug motor lead, noting which way it is fitted.,lever motor back and remove, replace brushes and refit motor and belt.
Mar 30, 2008 | Hotpoint First Edition FEW10P Front Load...
Creda
remove the rear panel screws, remove side panels, pull drum backwards, slide belt down front of drum and under, refit rear panel screws refitting drum at the same time, place belt around motor spindle and reasemble, job done.
Dec 24, 2007 | Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
