Question about Indesit BAAN134S
How do you reverse the doors on a indesit BAAN12 - WH fridge freezer?
Reversing the doors
If its a side by side like the one showing on your post, I doubt you can unless there is a spot showing for under the door, and the water and electrical lines are long enough to switch.
Mar 28, 2016 | Refrigerators
Hi, got a fridge freezer, the freezer door is not closing -please help
check if noting broke in the door locking mechanic. Or check if not too much ice is pressing the door open.
But if you don't hear the click, check the lock.
Feb 26, 2015 | Bosch Kge Series Fridge Freezer Door...
The doors open in the wrong direction
remove top screw for freezer door remove door then remove next hinge then remove fridge door reverse hinges when putting back on reverse handles to other side
Mar 01, 2014 | Thetford NORCOLD N641R - Norcold Finished...
How do you reverse the doors on norcold n641r fridge
remove freezer door first then fridge door change handles and reverse hinges
Mar 01, 2014 | Thetford NORCOLD Refrigerator Lower Door...
Reverse doors freezer hinge
What is the model number of your unit?
Nov 28, 2012 | Refrigerators
Whirlpool refrigerator door reversal
Check with supplier first but almost all fridge bodies are made for reversal
Apr 22, 2012 | Whirlpool Refrigerators
We have a Bosch Fridge Freezer Model No KGV3120GB/03 we wish to reverser hang the doors but can't undo the top post in the fridge and bottom one in the freezer don't want to apply too much pressure in case...
We have just reversed the doors on our Bosch Fridge Freezer. The posts were very difficult to unscrew but was eventually possible using 2 mole grips. It is definitely a screw fitting. Good Luck.
Jan 02, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
We have a fridge/freezer, upright bought some 15 years ago. Works fine, but we wish to reverse the doors to right opening from left. Please advise how to do it.
if you can notice that the doors have plastic plugs to the other side of the hinge then it is design to be reversible.
but if there is no indication that you can transfer the hinge to the other side of the door, then it is not designed to be reversible and there is nothing you can do about it.
i'm not sure if the old fridge are designed to be reversible.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Refrigerators
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
Indesit BAAN134S Logo
Top Indesit Refrigerators Experts
Dado
Brian Coughlan
John Tripp
John Tripp
Are you an Indesit Refrigerator Expert? Answer questions, earn points and help others
