Question about Panasonic Washing Machines
Washing machine Error code E03
4 Suggested Answers
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
beltronic205
  • 1466 Answers
SOURCE: the washing machine does not spin and displays an
Make sure water pumping out if not check /clean filter
Posted on Oct 03, 2009
  • 6277 Answers
SOURCE: my washing machine washes then
You don't say what make/model it is and different machines have different fault codes unfortunately! So I'm going to guess- no promise ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 21, 2011
E03-51 error on dp 6030
Hello Sir; the error code you indicated is corona wire problem, check the charge & discharge unit the corona wire is broken or not, replace it if it does.
Oct 06, 2012 | Office Equipment & Supplies
Canon pixma mp280 error code E03
the solution is http://archer-pcaldia.blogspot.com/2012/11/error-e03-impresora-canon-mp280.html
Apr 27, 2012 | Canon PIXMA MP180 All-In-One InkJet...
Canon pixma mp495 error code E03
e03 is paperjam or out of paper error, make sure you have a decent amount of paper in the tray. open up all the doors on the printer and make sure there's nothing stuck inside the machine.
Apr 03, 2012 | Canon Office Equipment & Supplies
Error Code E03-36
pull out toner bottle from machine
shake it well
reinstall it
power off then on
code will bi reset
May 01, 2009 | Panasonic DP-C322 Copier
Dp 4520 error code E03-60
error e03-60 means waste toner collection. could be a problem with the mechanism that delivers the toner to the waste bottle. looks arround there
Oct 09, 2008 | Panasonic Workio DP-4530 Copier
E03-40 error code
panasonic dp-4520 copier. e4-02 error code
Jun 19, 2008 | Panasonic Workio DP-3520 Copier
PANASONIC UF-8000 ERROR CODE E03-20, copy function not working.
Error code E3-20 Main Motor Rotation.
Loud clicking sound fuser unit drive gears cracked not driving
Apr 01, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Washing Machines Logo
1,246 people viewed this question
Top Panasonic Washing Machines Experts
SteveAlaska
richie46
Are you a Panasonic Washing Machine Expert? Answer questions, earn points and help others
