Question about Ariete Cafe Retro Espresso Machine
Rubber seal for kenwood ES547 - Ariete Cafe Retro Espresso Machine
3 oil filters and they keep leeaking. What would cause this?
Rubber seal not sealing properly, possible causes:
1) smear engine oil on rubber seal and refit.
2) engine sealing face damaged, check and repair.
3) rubber seal damaged, replace seal.
Aug 14, 2015 | 2011 Toyota Camry
Want a seal for kenwood blender model bl300
That kenwood is a UK model so if your in the US it's tough to source. The ring you need should have an outside diameter of 76 mm and an inside diamete of 56 mm.
This is a uk ebay link with the exact part.
1 Kenwood BL300 Blender Liquidiser Rubber Seal Gasket
This is a us amazon link with something that might work but not exact. There is a uk amazon equivalent if that works better for you.
Amazon com kenwood blender seal
Feb 18, 2015 | Kenwood Blenders
Blocked Kenwood Cafe Retro ES547 espresso machine
you could try to run some vinegar through the machine and it may clear the tubes. you will need a few runs of water through after to clear the machine though.
Apr 21, 2010 | Espressione Retro 1385 Espresso Machine
Coffee machine kenwood model es547 ligts come on but water will not heat up
Try unplugging it for several iuets in an attempt to re-set it..
If not - could be that the heating eliment failed.
Jul 11, 2009 | Coffee Makers & Espresso Machines
Kenwood Chef A701A Blender needs new shaft seal
It uses a different thread = turn clockwise to undo - not the normal turn ccw to undo and the nut is attached to the 2 blades.
Jan 11, 2009 | Kenwood KM300 Chef Stand Mixer
Kenwood ES547 Cofee Machine
Kenwood Cafe Retro - ES547 : disassembly instructions:
I've just taken my machine apart - it took a little force & ignorance :-) - I found this URL with loads of useful photos etc, thought it might help
http://www.kenwoodservice.co.uk/product-files-kar/espresso_makers.htm
Aug 27, 2008 | Keurig B50 Coffee Maker
Ariete Cafe Retro Espresso Machine Logo
51 people viewed this question
Top Ariete Coffee Makers & Espresso Machines Experts
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Ariete Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
