Question about Cuisinart TOB-30 Toaster Oven with Convection Cooking
Toaster oven just stopped working...
Checked different outlets (that are known to work), still does not work
  • captainmike Jan 19, 2008
    TOB030 Cuisinart also just stopped working. The start button would not light and start the heating process. my e-mail is captainmc45@yahoo.com
With mine, the toaster function stopped working. The light lit, but the relay did not click. This happened about a year ago, but then it started working again. Now that my waranty expired, it seems permanent.
The relay requires 12V, but I only measure 5V (no audible click). When I pulled the relay, the drive went up to 12V, so the coil is loading down the source. Not sure whether the problem is the coil or the source. It would be nice to find a schematic. When I put the relay across a car battery, I heard the click indicating that the relay is working.
I cleaned the contacts, and get the same result.
Posted on Nov 29, 2009
    Problem Solver:
  • 5 Answers
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Posted on Apr 07, 2008
  • qwerqwer May 30, 2008
    You can try to clean the contacts with alcohol (and/or very fine sand paper) as stated in other discussions, but the fix is a near term solution and eventually the contacts will arc and pit again. This leads to higher temperatures across the contacts and if the contacts fail before the plastic cam melts, your free to address the contacts for cleaning again. Just remember this failure will occur more frequently each time. Once the cam fails (melts) your out of luck. Write Cuisinart and tell them how unhappy you are with your toaster oven. If you get the same response I did (we only will replace it under warranty) then feel free to recycle it (or throw it away) and spend your money on a delonghi (no affiliation - my hand me down 7 yr old one keeps working great) or another brand. Companies these days should have better quality control on the products (from china) they slap their name on.
    For the record, mine TOB030 has about 10 hrs run time on it before it failed @ 1.5yrs old. The inside is still brand spanking new!
    Just my 2 cents.
  • jawajames
    jawajames Jul 27, 2012
    My TOB-30 died recently after 5.5 years of use (well, the bake function stopped, though toast and broil still worked). I opened it up and found that the cam had melted on the first contact. boo.
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
My tefal avanti stopped working
something had been gone short due to the power socket.let the socket be ok but sometimes due to heavy voltage this could possibly happen.just check if somme parts is burnt ,turned black or smelling foul oudor,or when you on the machine now it passes burning fumes from some where.
Aug 11, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
Kitchen Aid KCO222OB toaster oven is not powering up
Hi I think you will need t take it to a repair shop as it seems the toaster had had an element short circuit there is a small safety diode in the mains circuit to save you from shocks, I would check if a new one might be cheaper than the repair eric
Apr 10, 2012 | KitchenAid KCO222OB Toaster Oven
I have an Oster toaster oven 6260. Looks very clean. My son got it at a garage sale. Day 1 worked fine. Day 2 plugged in doesn't go on no matter what knobs are turned. Tried different outlets. ...
It is possible that the controller switch or the trigger is absent so that the coils do not get the power from the mains circuit. it will be best if you can remove the mains plug and start tracing with a multimeter in continuity range( ohms) so that the connection is confirmed.
Once it is found that the switch does not switch on the power or has lost the connection even when it is put to the ON position then you can salvage the swittch from the older toaster to be fixed on.
If the coils have opened it can also be checked with the meter , specially since you have one top element working.
So using the inventory of the two toasters you can get one working.
Jun 17, 2011 | Toaster Ovens
I had a house with old funky wiring. I'm pretty sure it caused me to blow a fuse in my toaster oven. Can you tell me where the fuse is located?
The manual mentions nothing about any user serviceable fuse or reset. "Funky" wiring in your home shouldn't cause an appliance to fail. Wiring that is in poor condition usually results in blown fuses or tripped circuit breakers in the service panel, heat in places it shouldn't happen and of course, fires.
It is very possible that the outlet is worn to the point that it doesn't make very good contact with the toaster's plug and has caused the toaster to fail to heat up. Try removing the toaster to a different outlet and try again. Check the original outlet with another appliance or lamp, etc. to see if it works or not. Also, check to be sure any ground fault outlet hasn't tripped.
If the toaster fails to work as expected in another outlet, there's little you can do to repair without jeopardizing your safety - especially if you're not familiar with appliance repair. These appliances aren't really meant for disassembly - manufacturers don't want to be liable for "repairs" that end with injuries, burns and death so the make them pretty hard to take apart. Even if you are successful, they make even harder to reassemble without it looking obvious that it has been disassembled.
Take it apart if you want - learn about how it works and buy a new one. These devices don't rely on rocket science and the controls are pretty simple - but it is an electrical device and electricity isn't a hobby. Be safe. Be smart.
BTW - I don't want your money - I just don't want you to get hurt.
Goiod luck!
Feb 18, 2011 | DeLonghi AR690 Retro 1500 Watts Toaster...
Top element not working all wires are connected
Very possible the element on top has a break some where but maybe small enough you cant see it or could be hiden. If you have access to a multimeter put it to ohms and with it unplugged from the outlet take the wires off the element and check the element itself if the multimeter reads OL the element is bad.
Mar 08, 2010 | Black & Decker TRO651 Toast-R-Oven Toaster...
Krups FBC2 Convection Toaster Oven Simply no power at all.
Having a toaster oven and a coffee maker on the same circuit is asking the breaker to trip in the house electrical panel, but I guess that you have learned the drill: only one appliance on at a time. Try moving the oven to the working side of the socket (the two socket sections can be spit apart and power each half from a separate house breaker and wiring). If the oven now works, check for a tripped breaker in the house panel. If the oven still doesn't work, look for a reset button near the cord entry point. Many heating type appliances have a thermal fuse that opens when things get too hot, but you need to get inside the cover where the cord enters.
Oct 11, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
I have Toast-R-Oven TRO200 and it just stop working.The light indicating the toaster or oven is being used does not come on.I plug it into other working outlet and it is still not working.
You probably have a switch in the oven that has failed or a broken wire. These are basically the only reason it wont come on. The best bet is if it is old buy a new one or see how much it would cost to repair. Usually the cost to repair is almost as much as the cost of a new one and getting parts can sometimes take two or more weeks.
Oct 09, 2009 | Black & Decker TRO200 Toast-R-Oven Toaster...
Toaster Oven Unresponsive (Farberware Model# FT032055
I would check the cord or the plug before anything else. Plug another appliance into the outlet if it works try bending the male plugs on the cord slightly and try again. If this doesnt work call the man.
Feb 24, 2009 | Toaster Ovens
4 slice toaster blows fuse when toaster uses 4 burners
You will need to move it to a different outlet that is not on the circuit that you are using or just toast 2 slices at a time.
May 06, 2008 | Toastmaster 328 Toaster Oven with...
Cuisinart TOB-30 Toaster Oven with Convection Cooking Logo
2,028 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
ray gallant
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
