Question about Wasp Barcode Technologies 633808342197 Mobileasset Enterprise With Hc1
Wasp hc1 scanner wont scan in running mode - Wasp Barcode Technologies 633808342197 Mobileasset Enterprise With Hc1
How do you treat a wasp sting?
Vinegar wash for wasps, alkali sting.
Bicarbonate of soda for bees, acidic sting.
Dec 30, 2016 | Wasp Computers & Internet
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
My Wasp wws-800 works while in the docking station but not when removed, suspect li-ion battery but have not been able to find a replacement. Any ideas
your wws800 should have come with two batteries. One goes in the reception base and one goes in the scanner itself. You should allow for four to 6 hours to fully charge. When charged, scan the setup barcode on the bottom of the reception base and then the BASE code. This will allow your scanner to create a connection with the base. Give it 5 secs or so, you should hear three beeps.
Jul 20, 2011 | Wasp WWS800 Handheld
I have lost my installation disk for my printer. How can I install my printer on my new computer with out it SCANER
Hi
Please try to download the printer and utility software from the site of your printer then install it
Thanks
Boopathy.t
Aug 23, 2008 | Computers & Internet
Beep Setting
On the left, at the rear of the scanner, there are three holes.
Place your finger...!
Print this message and scan one of the following barcodes:
Dec 05, 2007 | Wasp WWS800 Handheld
HDR-HC1 power keeps cycling
I had this exact problem, and the cycling would stop after about 30 sec. and then function properly. I believe a circuit was confused, mainly because I used an older battery and let it run out till the batt was dead - accidently - and when I put in a fresh batt, it no longer cycled and works perfectly to this day.
Now if I can get my computer to recognize the camera via firewire, I'd be golden.
Mar 07, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
Problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Feb 07, 2007 | Wasp WWS800 Handheld
Wasp Barcode Technologies 633808342197 Mobileasset Enterprise With Hc1 Logo
35 people viewed this question
Top Wasp Barcode Technologies Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Wasp Barcode Technologies Office Equipment and Supply Expert? Answer questions, earn points and help others
