Question about D-Link AirPlus DI-524 Wireless Router
Cant connect my laptop wirelessly...
I have 2 Routers a DLink DSL-502T and a DLink DI-524 Wireless router, I can connect to the internet on my desk top using the 502T fine but I can only connect to the internet on my laptop using the cable, I want to connect wirelessly, It says theres a strong signal but when I unplug the cable it wont connect to the internet even though it says its connected... Im stumpped HELP!!!
  • Neville Vyland
    Neville Vyland May 11, 2010
    is there any sort of protection used like WEP etc on your wifi...
    check the wifi settings carefull....
  • 49 Answers
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Posted on Jan 30, 2009
I can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these...
you should type in 192.168.0.1.
In your request you have:
i can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these componets are hardwired to cannot.has worked fine for years but stopped suddenly!!!!!!!!!!!
Nov 11, 2010 | D-Link AirPlus DI-524 Wireless Router
Opening a port for webcam
hi friend
here is the spcifaction of ur router see it
Apr 07, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
DI-524 wired/wireless access point
Just for fun, make the router give out IP addresses starting at 192.168.0.101 forward. Configure the AP at 192.168.0.2 with no DHCP (the host will give out the addresses), a netmask of 255.255.255.0, and a gateway of 192.168.0.1. Now, let the laptop find DHCP, or give it a 192.168.0.x address where x is greater than 2 but less than 101.
How lucky is that?
Carl
Nov 19, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
My D 502T Adsl+2 will connect but when I try to
First of all, what IP address does the 502 give you when you plug into it alone? Do an IPCONFIG from DOS and note the numbers.
Now, what is the default IP of the 524. Is it the same as the 502?
If it is, change your 524's IP to something else, like 192.168.1.1.
If it isn't, please post back what your IP configuration is and what the link is, DSL,Cable Modem, PPPoE, or DHCP either fixed or variable.
Carl
Apr 01, 2009 | D-Link AirPlus DI-524 Wireless Router
Setting up a lan and internet thru MTNL triband
I suggests you to go for Linksys. It's a good product when it comes to wireless internet. Linksys router must be plugged in to the modem. On the back of the router, you can plug the vista on port number 1 then your win XP machine can go wireless at the same time.
Sep 16, 2008 | NetGear DG834G Router
Connecting with internet
Yes, that is possible since you have a wireless router. Router can share internet connection. Go to this link this will help you setup the wireless connection (secure it if you want)
http://www.portforward.com/english/routers/wireless/Dlink/DI-524/wireless.htm then on the very bottom there is an option how to Configure Windows XP to connect to your wireless network.
I suggest this because it would be better if there is encryption on the network so people wont be able to access your internet for free (unless you give them the security key)
Sep 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
Loss of internet connection
I had selected PPP....... option instead of Dynamic, now fixed
Apr 18, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
242 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
