Question about HP Photosmart Premium C309A All-In-One Printer
Need to remove piece of shredded paper stuck in the c309a ADF but can't unscrew the screws.
The feeder grabbed the paper and kept feeding it, thus mangling the sheet and making it impossible to 'remove gently' as HP instruct. I can't get into the feeder to retrieve the bits.... The same thing happened a few years ago and the HP technician couldn't get in either. They replaced the machine. Do you have any suggestions? I've tried feeding another bit through, pushing a card through, trying to dig the bits I can see out with a safety pin etc. So for no luck.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • HP Expert
  • 97 Answers
This video will show how to remove a part to get to a stuck piece in your printer's ADF. Hope it helps:
WP_20170601_002.mp4
http://www.303electronics.com/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Posted on Jun 01, 2017
Joed911
  • 4338 Answers
SOURCE: My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Feb 01, 2009
  • 6 Answers
SOURCE: HP office jet feeder won't work when trying to fax
the little pieces of plastic are the sensor flags which is why it will not feed, those are required to let the machine know that the paper is present in the feeder. No flag no feed. Look at the plastic thing try to figure out where it goes in the feeder if you look close, you will see a spot where they go.
Posted on Apr 23, 2009
efs_perpends
  • 1996 Answers
SOURCE: Paper stuck in adf of HP Laserjet 3380
Please follow the instructions for clearing the paper jam outlined in this article from the HP online support site. Here's another link with info on the manual feed in case you need it, and the home page for your printer in the event that a manual would help.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 20, 2009
  • 10 Answers
SOURCE: False
it's probably due to what i would call the print head blocker ( on your left handside of your printer head) that is broken . check it out! it also responsable to control how far goes the sheet before start printing.
Posted on Jan 14, 2010
  • 39 Answers
SOURCE: The automatic document feeder doesn't grab the
Generally, you could clean the document feed rollers with WD-40, or a platen cleaner, but better yet, you should replace the pads and feed roller and I think you could do it yourself with my roller kit:
Roller ***'y,ADF Pick-Up,M1522n/nf/M2727/CM2320mfp
Part no. 5851-3580
Posted on Feb 17, 2010
How can I fix a paper jam in my Panasonic 4530 ?
look inside the printer, some where in or around where the paper feeds from the area there is a piece of paper that is stuck or has ripped off inside the machine, you going have to look with flashlight follow the feed rollers and you will find paper, paper clip, a staple, dirt, something blocking the rollers or feeder from working right.
www.ask.com/panasonic_4530_paper_jam/
www.ask.com/panasonic_4530_error_code_j50/
www.ask.com/panasonic_4530_where_is_paper_jam_located/
Apr 22, 2015 | Panasonic WORKiO Office Equipment &...
Hp 309a DADF out of order
you will need a T10 to take all the screws out and clean the paper from the feeder or you can take the printer to a HP service partner to get it repaired for you.
Nov 11, 2013 | HP Photosmart Premium C309A All-In-One...
We bought an used Canon NP7130F and it didn't come with an user manual and we can't figure out how to get the auto feed to work. We put a piece of paper in the top feeder and it starts to grab it but then...
Unfairly, that feeder has it's own issuse's > it was a very bad design from Canon > It works really good or not at all.... There is a tech pub for a new drive motor for the doc feed belt & new sensors for the paper path..... It may also, be that it needs new adf feed rollers..... Did it work before you got it? If soo, I'd call the person you got it from and have them fix it. Or you can call a service person. The copier is a tad bit old....... Good Luck
Apr 25, 2011 | Canon NP 7130 Black and White Copier
When I try to fax something before the paper feed all the way though the alarm sounds and a message says doc in adf. how can I fix this problem
It sounds like there's debris stuck in the ADF. Try blowing it out with a can of compressed air. After time, paper dust will accumulate in the feeder and occasionally block a sensor. Once clear it should work. If not, there is probably a small piece of paper lodged in the feeder. If this is the case, try using a paper clip to feel around inside the feeder to poke loose any fragments.
Feb 18, 2011 | Computers & Internet
How to clear adf paper jam?
adf is the top part of the printer from where you feed the paper for copying. adf is automatic document feeder. open the top cover and see if there is any paper in it, remove the paper and close it again and it will reset the paper jam.if it doesn't reset then there could be a small piece of paper stuck somewhere.
Jan 06, 2011 | HP LaserJet M1522nf Multifunction Printer...
Ep1083 copier
If the machine sees the ADF ( auto document feeder) but does not feed the paper? Does it try to feed the paper? Does it pull the paper is a little and jam? If the machine sees the ADF and it starts to feed the paper but jams --- clean the feed rollers/ tires with rubber restorer or a high alcohol base cleaner. Also a mylar could be pulled into the paper path blocking the feeding of the paper. Take a thin piece of cardboard ( like the devider in a case of pop) and slide the cardboard about 3- 6 inches into the feed just past the feed roller. Gently pull back out and try to feed paper again. If those do not work and the machine does see the ADF, you may need switch, sensor, actuator or feed motor.
Aug 27, 2008 | Minolta EP1083 CS/PRO Copier
Paper jams in document feeder
if u can do it,u need a special screw driver called T10,open the adf cover fist,there u can see four screws fitted at four cornersn one at the back,unscrew them,the adf unit will come out clean it properly,n also look for any peice of paper or anything like broken plastic etc,clean it n fix, n check
thnx N
Jan 29, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Jam in the document feeder
I think I found my answer. You don't have to un do any screws. Lift up the cover to the automatic feeder. You will see a spring on the side of the mechanism towards the front; remove the spring; that will allow you to lift up the little arm the spring was attached to and remove the roller or bar and the light blue/green plate just under it. Then you will be able to see the jammed paper, which which I was able to carefully pull out with a pair of tweezers. Some was under rubber rollers, but when I pulled the paper sideways it slipped out. Now it works!
Jan 23, 2008 | HP OfficeJet 7310 All-In-One InkJet...
ADF document feed
Hi, The problem seems to be a piece of debris , paper stuck in the ADF roller assy. You can check this by opening up the adf cover and inspecting the paper path. I have seen where a very small peice can cause paper path problems to where something is blocking the paper> Good Luck!
Dec 03, 2007 | HP 5590 ScanJet Flatbed Scanner
SUDDENLY THE ADF DOSEN'T WORK I GET AN ERROR MESSAGE THAT THERE IS A DOCUMENT IN ADF REMOVE AND PRESS OK
Problem:
I place a stack of originals in the ADF and press Copy or Scan. There is a sound of a motor running, a pause, and then the motor running again. The paper is supposed to feed during this second phase but does not always feed. For me, it would fail to feed, ask me to clear the ADF, and press "OK" a random number of times and then suddenly it would work once or twice and then fail again.
Diagnosis:
I am a retired engineer and my feeling was that if could work properly even once, then it should work every time. The problem must be something intermittant relating to temperature, humidity, age, etc. It must be easily fixed.
Solution:
The rear of the ADF has a silver-grey plastic piece which covers the feed motor and gears. You gain access by removing the one Phillips screw, opening the lid, and carefully prying the retaining lip at the right end of the silver-grey piece until it lifts up. The piece is then removed by sliding the retaining "leg" free at the right end of the piece.
Inside, you will see some white plastic gears. One gear is mounted on a floating idler arm. This gear controls feed and reject (I think). The feeder fails when this idler does not flip freely from one positon to the other. Carefully place a SMALL amount of very light (low viscosity) oil on the ider arm and verify that if easily moves back and forth.
Test the unit before replacing the silver gray cover piece.
That fixed it for me.
Email if you have questions.
Sep 05, 2007 | Canon PIXMA MP830 All-In-One InkJet...
HP Photosmart Premium C309A  All-In-One Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
