Question about Emerson MW8102SS 1100 Watts Microwave Oven
No power I set the time this morning, pressed start, heard the normal "thud" when the thing stats but directly after the thud all power was lost. Tried different outlet to be sure I didn't just flip a breaker, with no luck. Really like this model, otherwise I'd already be at Target.
  • 909 Answers
Your fuse is definately blown. possibly moisture. if you replace exact fuse and it blows again, powerside is defective.little bit tricky then as you have diodes, capacitor and magnatron also transformer to check. these need testing equipt.if you decide to press on, caution, capacitor is fully charged and dangerous.
Posted on Jul 23, 2007
How to set the clock on ge space maker micro wave
http://products.geappliances.com/appliance/gea-support-search-content?contentId=17872
Quoted from link above:
To set the clock on most GE microwaves:
  1. With the microwave door closed, press CLOCK.
  2. Touch number pads that reflect the time of day (1:45 would be 1, 4, 5).
  3. On some newer models, indicate AM or PM for morning or evening.
  4. Press CLOCK or START to lock in the time.
If you prefer not to display the time:
Disconnect the power for 30 seconds. After restoring power, do not set the clock. If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Mar 21, 2018 | GE Microwave Ovens
My LG LRMP1270ST microwave oven stopped working in the morning. It just flat died when I put 2:00 minutes on the timer and pressed start I heard the pop/breaking sound. So immediately I stopped the...
The main fuse has blown in the microwave, you also have secondary problem that sounds like the magnetron has failed, but there are two other parts to consider, the high voltage capacitor and diode work in conjunction with the magnetron to heat the food. The repairs could run as high as a new microwave oven.
Feb 14, 2011 | LG Microwave Ovens
I SET THE TIME I WANTED THE MICROWAVE TO RUN AND WHEN I PRESSED THE START BUTTON I LOST ALL POWER I CHECKED THE POWER SOURCE TO THE OVEN AND HAD POWER HOWEVER NOTING ON THE SCREEN OF THE MICROWAVE. WHAT...
Hi Bill. it is possible that you may have just blown a fuse. Check the fuse and replace if it blows again check all the diodes in the power supply. If one reads in foward and reverse bias please replace dides should only read in one direction. If these diodes are not shorted check all the diode in the microwave especially the large one connected to the large capacitor. Make sure you discaharge the capacitor before troubleshooting this section because it can shock you even when the microwave is unplugged. If any diodes are shorted replace them this will fix your problem.
Nov 08, 2010 | Kenmore 80012 Microwave Oven
I have a Hamilton Beach 0.9 Cubic Feet 900-Watts Digital Microwave Oven and I can not find out how to change the power setting for cooking.
Assuming its the same as my Hamilton Beach, you first enter the cooking time, but don't press start yet, instead press power, then a number button 1 - 9 for the power level 1 for 10%, 2 for 20% etc. THEN press start as normal
Oct 29, 2010 | Microwave Ovens
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Good morning: ) may I ask you a question about my
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If some keys are still not working, then you likely have a bad keypad.
I would need your brand and full model number to give you a free estimate.
Feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 14, 2010 | Microwave Ovens
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
Mar 30, 2009 | LG Microwave Ovens
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
Don't understand how to set the power levels
Is your full model number MW8675? If not, please post your full model and let me try again.
Normally you press Time (or Time Cook) then the digits of the time, then Power, then a number from 1 to 9 (which stands for 10% to 90% power level), then Start.
On some models you just press the digits of the time, then Power, then a number from 1 to 9 then Start.
Many Emerson microwave manuals are available for free download here: http://www.emersonradio.com/owners/MWO%20manual/
If your is not there, try one with a number close to yours.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 24, 2008 | Emerson MW8777W Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
50 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
jason
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
