Question about Lorex SG6153 / Weather Resistant Mini Color Camera with Night Vision
Wiring schematics lorex mc6941 - Lorex SG6153 / Weather Resistant Mini Color Camera with Night Vision
Lorex wireing diagram
Request the diagram directly from Lorex.
Aug 22, 2016 | Lorex Home Security
Lorex SG 6157 need to know what the four wires go to blue black re yellow
Red & Black are PRETTY MUCH always the Transformer Pwr (12v delivered: (9V DC working...Red is positive)).
So the video should be your yellow & blue/
(I thought green (but what do I know)).
ImageSensor:1/3"ColorCMOS, VideoFormat:PAL, EffectivePixels:628Hx582V Resolution:330TVLines-SyncSystem:Internal, AES:1/50~1/1500Sec Min.Illumination:2Lux, Lens:6mmF1.8, ViewingAngle:Diagonal53? OperatingVoltage:9VDC, OperatingTemperature:-10~45degreeC Dimension(WxDxH):53x80x49mm, EnvironmentalRating:IP44
I have every confidence your cables are going someplace EVEN MORE COMPLEX you have not even mentioned. You really need to share that BEFORE DEFINATIVE answers can be given abort ONE end of your cable.
The primary question
Are you using Philips/BNC (cannon-PWR)/ connectors or the RJ45 type... using individual power transformers or Power Distribution panel... Direct to a video screen (TV monitor).. or a NVR real-time matrix... or DVR recording system
Comment back if you are serious with configuration information... If I don't know your answer straight away I can get you pointed in the right direction.
Required Pin-out, nvr, dvr, resolution, compression, remote, IP
lorex sg6157 wire pinout Bing images
Lorex SG6157P Specifications
Jan 14, 2015 | Lorex SG6157 Indoor/Outdoor Color Camera...
Wires cut on my lorex mc7520 color camera how do I wire
http://www.lorextechnology.com/downloads/security-dvr/SG19LD-SG17LD-Series/SG17LD800&SG19LD800_SERIES_MANUAL_EN_R3.pdf
I hope you have the rest of the system since the monitor powers the camera. If you have the end of the cable with the connector on it then just splice the wires color for color. If not then you're out of luck.
Oct 01, 2014 | Lorex Home Security
5 wire security camera wiring diagram
standard cctv camera wiring
red for + 12v
black for comm
yellow for + v (+video signal)
white for -v (-video)
Jul 09, 2014 | Lorex Corp SG6184S Weatherproof Mini Color...
One lorex camera dont displayed
CHECK POWER SUPPLY TO THAT CAMMERA ALSO IF WIRELESS MOVE CLOSER TO BASE UNIT SEE IF THAT HELPS ANY
Feb 10, 2014 | Lorex Home Security
Too much power and now lorex camera wont turn on
CAMMERA DESTROYED !! MOTION LIGHTS USE 120 VOLT AC POWER
CAMERAS USE 12 VOLT DC POWER
WRONG TYPE AND AMOUNT OF POWER !!!
Jan 16, 2014 | Lorex Home Security
Lorex mc6996 4 wires connect to what? red, white, yellow, bare copper wires
Call Lorex
1-888-425-6739
Otherwise it appears this is 24V DC camera that requires DC transformer.
Photos of the product show plug-in connections.
That seems inconsistent with description, implying that incorrect model number was given, or this is a used product that was taken apart?
Add a comment.
Attach a photo.
Apr 19, 2013 | Hardware & Accessories
Wire diagram for Lorex mc7520
The primary source of a diagram would be Lorex
Apr 05, 2013 | Lorex SG6153 / Weather Resistant Mini...
, 1-need schematic to rewire a lorex color camera model no:MC7555R i have five wires coming out the back of the camera 1'
The RED wire is your 12 volt power "positive". The BLACK wire is your 12 volt power "negitive" The YELLOW wire is your camera video. The white wire is your cameras audio & the copper wire is shielded ground.{Davesajak}
May 01, 2012 | Lorex SG6153 / Weather Resistant Mini...
Lorex SG6153 / Weather Resistant Mini Color Camera with Night Vision Logo
135 people viewed this question
Top Lorex Home Security Experts
Henry  Thomas
Henry Thomas
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
