Question about Pioneer AVH-P4100DVD Car DVD Player
Reset avh 2400bt - Pioneer AVH-P4100DVD Car DVD Player
My pioneer avh-x3500bhs keeps resetting itself
Mine does the same thing, its not a wiring issue as I put a different Pioneer Head Unit in its place and the problem went away. I put it back and the problem returned
Jan 16, 2014 | Pioneer AVH-P4000DVD Monitor
AVH-p4450bt can't connect to bluetooth saying Error-10 help!!! :(
my avh p 4450 radio shows error10 don't want to pair up how do I reset radio I did plug it out already and theres no reset button on radio thanx
Feb 02, 2013 | Pioneer Avh-p4450bt 7" Bluetooth Gps...
I have a AVH-X2500BT I am trying to play a dvd. an error code 02-9e comes up. what is the problem?
The error indicates that the AVH-X2500BT can't read the disc. The DVD could be dirty or scratched or upside down in the tray. Try cleaning the disc or putting in another DVD. The other issue is a mechanical or electrical problem with the unit. Turn off the car's ignition then press the Reset button on the unit. The reset button is recessed and has to be pressed with a pen tip (it's on the far left of the front button array).
The manuals for the unit is available here: . See page 4 (page 7 of the PDF) for the location of the Reset button. You will need Adobe Reader or a similar program to read the manual. If the reset doesn't work, you ,may need to have the unit serviced. (Check that your electrical system doesn't have any fuse or ground problems first.)
I hope this helps.
Jan 10, 2013 | Pioneer Audio Players & Recorders
Pioneer avh p5750 screen wont close
look for a small reset button behind face. or unplug the unit, wait 30 seconds and reconnect.
a simple reset should do the trick.
Nov 22, 2012 | Pioneer AVH-P6500DVD Car DVD Player
Pioneer AVH-P4900DVD screen calibration..can it be done?
Hold the and boost at the same time and press reset with a pin once screen resets let go of 2 buttons, this is the service menu and I cannot get any farther
Mar 21, 2011 | Pioneer AVH-P4900 Car Video Player
AVH-P5700DVD Car DVD Player: how to re-calibrate the touch screen for a Pioneer...
In order to calibrate the AHV-P5700DVD you need to press and hold the Boost and the + button and then press the reset button with a pen. continue to hold the Boost and + until the screen opens back up and you can see the calibration screen. use the arrow nob on the right to select the menu item, and the A button to select your item.
May 17, 2010 | Pioneer AVH-P5700DVD Car DVD Player
I have an Avh-p4100 and the IU200V cable. My DVD was playing the videos, but now it simply doesn´t play videos anymore. The cable´s plug is right conected back the DVD, and in the initial menu,...
Try resetting the unit using a pen. While powered on, click the reset button and this should resolve your problem. If it doesn't the problem maybe related to parking brake cable not being connected properly.
Mar 04, 2010 | Pioneer AVH-P4100DVD Car DVD Player
My Pioneer AVH-P4100 DVD just beeps...
could it be a ground or is the ant. plugged in
Aug 20, 2009 | Pioneer AVH-P4100DVD Car DVD Player
I have the same problem. I conect the red and yellow wire at positive battery and the black wire to ground, but it doesn`t work. I press the reset button and nothing. I am try to turn it on with a power supply. could you tell me or show with a picture how to conect All?
It`s AVH - P5000DVD
From Venezuela.
Aug 19, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Open Questions:
See all Pioneer AVH-P4100DVD Car DVD Player Questions
Pioneer AVH-P4100DVD Car DVD Player Logo
289 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
