Question about Fujitsu fi-6770 Flatbed Scanner
Sa01020e says scanner not connected - Fujitsu fi-6770 Flatbed Scanner
Driver for fi-6130z
Your problem is not the driver of that scanner but the system corruption of Windows 8.1 and if you don't solve this issue now, you'll be suffering this "karma" until system finally collapses.
If Windows 8.1 update went wrong, EVERYTHING is wrong. You should backup all your data and do a factory reset for Windows 8 and then update to Windows 8.1
If Windows 8 came preinstalled in your laptop you should have a recovery partition on your hard drive.
There are several tutorials how to do a system reset. Read them and follow the one you best understand.
Reset your PC from Windows 8 Recovery Drive
How to reinstall Windows like pro
How do access Windows 8 Recovery partition and how to recover it to...
How to refresh reset or restore your PC Windows Help
Jul 19, 2015 | Office Equipment & Supplies
Tip
How to connect barcode scanner to your pc
In order for them to be useful, barcode scanners often have to be connected to computers. We will recall that in virtually all cases, the data which gives meaning to the barcodes they read is stored in databases, which are in turn hosted on computers. What the barcode scanners are meant to do, then, is to transmit the data they scan to the computer, with the computer checking that data against the database in order to assign meaning to it. In most cases, then, scanners without computers will tend to be quite useless. For a scanner to be useful, it has to be connected to the computer. And what we are interested in, for this discussion, is gaining an understanding of the ways through which barcode scanners connect to computers (at the simple, physical, external level).
As it turns out, there are four main ways through which barcode scanners connect to the computers which host the databases upon which they depend:
1. Serial port connection: this is where the scanner comes with a pin which you simply hook onto the serial port of your computer (like where you would hook an extra mouse), and thence connect the barcode scanner to computer. It was, arguably, the first method for connecting barcode scanners to computers to be developed. Its disadvantage is that it is not a plug and play approach. You have to go through quite a lengthy installation process for the barcode scanner, when you go this way. Furthermore, should the scanner 'hang' somewhere in the middle of a computing session, you don't have the option of just unplugging it and then plugging it in again to see whether it will work. Instead, you have to restart the whole machine again, and this can be very disruptive, for instance in the midst of a shopping checkout for a hurried customer. In this system, a scanner would also need specialized software to connect to various computers, meaning that there was no universality in scanner usage.
2. Keyboard wedge connection: this is a connection method where the barcode scanners are put in somewhere between the keyboard and the computer as a 'wedge.' It is something of an improvement on the serial port connection.
3. USB connection: this is what is to be found on most scanners, today. It is where you connect the scanner to the computer using any USB port. A scanner made in this way can, therefore, be used with pretty much any computer. Should it stall midcourse, you have the opportunity to just unplug it, and plug it again, to see if that solves the problem (which it often does). It is also convenient, because in this approach, connecting the scanner to the computer becomes as easy as connecting a USB flash disk to the machine.
4. Wireless connection: this is the emerging technology in ultra-modern scanners, where using systems such as Bluetooth, they are able to connect to the associated databases wirelessly.
on Oct 05, 2010 | Computers & Internet
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
Jan 22, 2015 | Office Equipment & Supplies
I tried to connect my Canoscan lide 90: when I try to scan: my computer doesn t seem to connect to the scanner: try the cable, connection and turn the scanner on. The connections seem to work... how do I...
Hi ,
The driver is probably missing . You can download and install it from here :http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide90#DriversAndSoftware
Best regards .
Aug 04, 2014 | Canon CanoScan LiDE 90 Flatbed Scanner
Can't find scanner
Is the scanner visible in Device Manager? If not you have a hardware or connection issue.
Is the connection USB or network? If network have you checked TCP/IP settings? If USB are the USB items OK in Device manager?
Is it an old scanner connected to a new Windows version such as Win7. Some old scanners are not compatible.
Jan 11, 2014 | Microtek ScanMaker 9800XL Flatbed Scanner
What leads to connect scanjet 5470c scanner
First, a power adapter is required to connect your scanner. the power adapter must be supplied with the scanner. If your scanjet 5470c scanner is having USB interface or connectivity, then you need USB cable and if it is SCSI interface, then you need SCSi cable to connect to your PC. The cables are usually be supplied with the scanner. If lost, you may have purchase teh same. For further assistance, please visit the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=15179&prodSeriesId=28456&taskId=115
Hope the above information is helpful.
Thanks,
ScanCare
Jun 25, 2012 | HP Office Equipment & Supplies
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
ScanAllPro starts, chose the scanner shows the error: scanner is not connected or another application is using it. but no application is used at this moment. and the test with document scanning by...
Hi,Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.Specify which driver is used for the scanner, the TWAIN or ISIS/VRS driver. When a scanner is no longer connected to a USB port to which it was previously connected, this option checks if any scanner of the same model has been connected to the other USB port. If the same model is found there, this option automatically switches to the other port and inherits the settings of the same model.
* This option will not be available, however, if a different model has been connected to the port where the scanner was previously connected. * Disable the settings when you want to connect more than one scanner of the same model to your computer.
Thanks,
ScanCare
Jun 24, 2011 | Fujitsu fi-5120C
I try to scan a document and it says that I am not set up on pc. I use just the scan button and it still won't scan. Help please!!!
Verify cables connected properly to the back of the scanner
If the scanner is a parallel port scanner it is likely it has two available connections on the back of the scanner. Verify that the cable coming from the computer is connecting to the IN, Computer IN, computer, or similar connection.
Ensure that the scanner is getting power
If your scanner is not getting power it is recommended that you check the connections ensuring that they are connected properly to the back of the computer and from the scanner to the wall. If you have the scanner connected to a power strip and or surge protector it is temporarily recommended that you connect the scanner directly to the wall.
If the computer scanner is getting power, you should notice the inside light come on when the power is first received by the scanner.
After checking the connections you still get no power to the scanner, it is recommended you contact the manufacturer of the scanner.
Additional parallel port scanner troubleshooting
If you have another device connected in between the scanner and the computer, turn off the computer and temporally disconnect the devices connected to or from the scanner. If, after disconnecting these devices, the scanner works, it is likely that another device may have issues or may be unable to work with other parallel devices.
PC Windows users verify no TSRs are running in the background
Press CTRL + ALT + DEL and end task all currently running software except explorer and systray and attempt to scan again. If this resolves your issue it's a possibility that an application in the background such as a virus utility is preventing your scanner from scanning.
Verify the LPT port mode
PC users ensure that the LPT port mode within the computer BIOS is set to either EPP or bi-directional mode and/or try alternating between these two modes.
Update the drivers
Verify that the latest drivers are installed for the operating system being used on your computer. A listing of computer scanner manufacturers and links to the drivers pages can be found on our scanner drivers page.
Nov 19, 2009 | HP LaserJet 3055 All-In-One Printer
HOW TO CONNECT SCANJET 5470c to computer
Hope you have a hp 5400 software CD which will install the programme of the scanner to your PC. Once this is done then you will be able to connect and operate your scanner with PC.Your PC should have a USB port to connect the scanner with it.
Ajit bhutani
May 20, 2008 | HP Scanjet 5470c Flatbed Scanner
Fujitsu fi-6770 Flatbed Scanner Logo
67 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
