Question about Venturer Audio Players & Recorders
Can't get all speakers to work - Venturer Audio Players & Recorders
My venturer surround sound will not work with my smart tv built in surround sound
Posted on Sep 07, 2013
Need help with altec lansing ada 745 4.1 speakers
Does the right front speaker need to work in order for the whole speaker system to work?
The whole system can still work with or without it.
Here is an additional tip how to ..... Computer Speakers
Sep 29, 2012 | Altec Lansing ADA745 4 Speakers
Altec lansing ATP4 speakers aren't working
is it possible that you may have plugged the speakers into the microphone or audio input jack on the computer instead of the speaker/headphone/audio output jack?
Apr 28, 2017 | Altec Lansing Audio Players & Recorders
JBL speaker's woofer occasionally cuts out - tweeter still works.
Your driver has a damaged voice coil, you can either find a speaker repairer to replace the voice coil or find a replacement driver to fit.
Mar 05, 2012 | JBL Northridge Package System
I have an Onkyo TXNR609 home theater receiver hooked up to a 6 speaker surround sound setup in the living room. I also have 2 speaker pairs outside - one on the downstairs patio and one upstairs. I was...
If you haven't done already, then verify that zone 2 works without the selector. If the speakers definitely work and the zone output definitely works then the speaker selector must be the culprit! It's pretty difficult to mess up the wiring with speakers, as even if polarity is reversed, you will still hear something.
Sep 23, 2011 | Niles SSVC2 Two Pair Speaker Selector...
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
Using only Stero speakers. Sound only from right speaker. Left not working. However if I select tuner (not tuned in) the speaker works. Diconnected wires numerous times. Any help would be...
Hello
Check its audio settings. If the 'balance' control is at its one extreme, one speaker of that side son't work. When you select 'tuner' the the set sutomatically goes to 'Mono' [according to selection]; and both speaker will work. Check if stereo option is activated in its audio option first. If not, select it to stereo, dolby digital or so what you want ot hear. If all selections are OK, and still the problem perists, its digital processing section should be troubleshooted. Actually this is not a user repairable option. Contact any experienced service personel or Panasonic Authorised Service Center at your town. OK.
Jun 29, 2011 | Panasonic SA-HE70 Receiver
Speakers work at low volume. Around -39 db, receiver shuts off.(protection mode) Tried moving speaker wires, alternating red and black. No go. When powered back up, display says ck sp wires. Once I...
Decibels correspond to the output voltage being sent to the speakers. In your case, the voltage is reached at -40dB is the threshold that causes whatever is happening to operate the receiver's protection circuit. You might have a bad speaker, with a voice coil that shorts at the higher voltage. Below that level it's okay, but at the magic point the insulation breaks down, and that's when the receiver sees trouble.
You might try connecting only one speaker at a time using a short length of wire other than your current ones. If the trouble occurs on one speaker only, you've found the culprit. If the receiver operates normally on each speaker, try reconnecting one speaker at a time to determine if one of the speaker wires may have a short somewhere. There might be a weak spot in the insulation, not causing any trouble until the voltage is high enough.
If the receiver still goes into protection with just one speaker, there's an internal problem. Some part in the amplifier may be breaking down at that voltage. Or a part value has changed, causing the protection circuit to kick in even though there's really nothing wrong. Bad solder connections may have developed. Unfortunately, this kind of problem usually needs the services of a shop with the equipment and circuit information to figure out what's happening. If you can find a Yamaha-authorized warranty servicer, they might already know some typical causes if they've seen units with the same trouble.
Try the speaker test first. Then let a shop tackle the receiver if it looks like that's where the fault is. Good luck and thanks for using Fixya!
Jun 03, 2011 | Yamaha HTR-5830 Receiver
Can't get the speakers to work?
Have you bought them new? Try using an mp3 player to test them. If they're working fine with another device, the problem is your main device, the computer or else.
If it's a computer, try reinstalling your audio drivers, better do it in the safe mode.
If it's just another mp3 player or a similar small device, try using that device with another speaker or headphone to find out, whether it's the speakers, that's causing the problem or not.
If the speakers are not working, return them to the place you bought them.
Apr 18, 2011 | Logitech X-230 2.1 Speakers
65 people viewed this question
Top Venturer Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Venturer Audio Player and Recorder Expert? Answer questions, earn points and help others
