Question about Dell Inspiron 1501 Notebook
File sharing between computers
I have a Dell laptop with WiFi, Windows Vista Home Premium connected to a Lynksys WiFi router with several desktop computers connected via ethernet (cat5) to the router. Is there a way to share folders/files between the laptop, and one of the desktops which runs with WindowsXP and all service packs installed?
  • easyonce Jan 27, 2009
    Do you have to configure every pc hooked up to the router, or can you just use one of them?
  • easyonce Feb 01, 2009
    Sorry I haven't got back yet but I've been sick. I didn't have any problem setting the dell laptop up, but for some reason, I can't get one of the desktops configured right. By the way, my goal is to be able to access either the slave drive connected to the desktop, as well as a USB drive from my dell laptop. Any solutions if it can be done would help.
  • 124 Answers
Thanks for giving me the opportunity to help. Try the following:
On your laptop with Vista, click start, then network from the right side. This will take you to the Network Screen. Click on the Network and sharing screen. Click on options such as file sharing, printer sharing etc. Make sure that you can see each device your your network. If you can't you must go to each PC and use the network options on the XP machines. It's pretty simple, just follow the instructions that the wizard provides.
I hope this gets you up and running. Thanks for using Fixya.com
Posted on Jan 27, 2009
  • Bernie Thames
    Bernie Thames Jan 28, 2009
    You can use just one....Don't forget to give me a rating if I've helped you!! Thanks!
  • Bernie Thames
    Bernie Thames Jan 30, 2009
    I was wondering if you still needed help? If you were able to use my
    suggestions to fix your problem, I'd appreciate a rating so my boss
    knows I'm doing right by my customers. Thanks!
I want to start a network between my laptop and desktop
There are lots of guides on the internet...
BUT as a minimum you will need...
All the computers on your home network connected through the same router (Wired or Wifi).
All the computers on the same "Workgroup"..Choose a workgroup name and change all the computers to the same workgroup.
You will then need to change the properties of any drive/folder or files to enable sharing.
You can also drag stuff into the shared folder.
This can still be quite hit and miss, especially if your computers are using different versions of windows.
Good luck
Jul 21, 2010 | Dell Dimension 4700 PC Desktop
Vista to Vista wireless, Can't share printer
So your third laptop which runs Vista cannot connect to the Printer and Dell machine?
There are some reasons for that. First check whether you have access to the Dell machine (whether you can reach it) Open a command prompt and do a ping to verify the connectivity. Example. ping 192.168.1.2 (The ip address should be the one of your dell machine. You can find it by running ipconfig in a command prompt on Dell machine.)
1. If you cannot reach it you have to check the network utility (wifi or any other method you use). Make sure that it function properly. 2. ping the router using router's ip address. If ping works you can reach up to their. So from there you can check the Lynksys management console to know why it blocks the machine entering the wlan. May be a addressing issue or authentication issue. If you cannot reach it however it might have problems with the connection as well. Make sure that you allow connections to the wlan on Toshiba Vista laptop if you use a antivirus solution with a firewall or any other firewall.
If you can reach the machine (or even if you cannot reach) you must check whether you have access to the workgroup (you have to join if you are not in the workgroup which you use) and you must enable file and print sharing. If you run the windows firewall that would block you in as well. Its better if you can check whether the print spooling service runs. Start -> Run Type in services.msc Hit enter. Check and enable the service.
If you can reach the Dell using a ping: Check whether the dell machine can access the laptop. Use my network places. It will ask you for the credentials. Provide them. If any error occurred try detecting the network. Add the machine properly to the workgroup. Enable access to the machines via file and print sharing in windows firewall. (go to the firewall go to Exceptions tab and select the File and Print sharing)
Check this Microsoft resource as well.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 30, 2010 | Linksys WRT160N Wireless Router
Can't get epson Stylus nx400 to print from wireless laptops. printer connected to desktop with windows xp pro. both laptops use windows vista home premium.
As your printer is not wireless itself you need to shared the printer. To enable this goto Control Panel on your desktop, select printers, right click your printer and there should be an option for sharing. Enable sharing.
Now using your Vista laptops you should connect to your home network (in your case this is probably a wireless router, as long as your desktop is connected to this router too), goto Control Panel, printers, add printer, search for printer not connected to this copmputer (or network printer).
Hopefully the Vista laptops will then pick it up and install it correctly. You may be asked to install the correct driver for the vista machines. Windows should provide you with instructions on how to do this.
Hope this helps, www.PuterCare.com
Feb 20, 2010 | Epson Stylus NX400 InkJet Printer
I've just set up a wireles network at home. My desktop and laptop are conected to a Belkin router. Th desktop has McAfee firewall etc installed. I think I've done everything ok on the set-up. When i...
ok you will have to set up printer and file sharing on both machines. not to familiar with vista but its similar to xp. if you open my computer or windows explorer right click on the folders you want to share. the Macafee thing not to sure but you should be able to make an exeption for file and printer sharing
Jan 03, 2010 | Computers & Internet
Setting up HP C6180 to wireless laptop
if your desktop and laptop connected with same network then open the printer windows on the desktop computer, do the right click on it and select the share option.
after that select the share for everone and click on ok.
then on vista computer open the printer windows and click on add printer after that you will get the option local printer or network printer.
Select the option "network printer: and click on next and click on find the printer and select the printer and click on finish.
good luck
Aug 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
Computer file sharing
first check,
laptop and pc is in same workgroup.
then,Right ckick on the file---------------share and security-------------cilck on blue under line like if you understand security risk....................................--------------then choose just enable file sharing---------ok
its done!
Jan 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Laptop accesses network, but not desktop
you need tocheck the sharing, on both pc's go to taskbar on right, right click the network icon, click network and sharing centre and ensure the sharing buttons are all on.
Make sure thay are also on the same workgroup, right click my computer icon>properties>advanced system settings>click computer name tab and check the workgroup name is the same eg both mshome or workgroup
Sep 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
Just purchased laptop with windows vista home premium
If your PC has a wireless card, you can setup an AD-HOC network :
If your PC is XP: http://www.microsoft.com/windowsxp/using/networking/setup/adhoc.mspx
If your PC is Vista: http://windowshelp.microsoft.com/windows/en-us/help/293c504f-b944-4d5d-835c-f080129bd5dc1033.mspx
If your PC only has a wired Ethernet connection, you may still connect the two using a Wireless Access Point/Router.
Once you have the two computers connected, you may do whatever networked operations you would like:
File & Printer Sharing is the most common:
XP: http://www.wellesley.edu/Computing/FileSharing/Windows/win2kxp.html
Vista: http://www.windowsnetworking.com/articles_tutorials/File-Print-Sharing-Windows-Vista.html
Aug 01, 2008 | Apple iPhone 3G
Dell Inspiron 1501 Notebook Logo
103 people viewed this question
Alun Cox
