Question about Panasonic PT-53WX42 53" Rear Projection Television
Unit will not power up. No power light.
I replaced the two STK392-110 IC's and a 2.2 ohm resistor, (board was removed by someone else), after reassembling the unit it now does nothing. The original problem was the power light blinking three times. When I plugged the power in I saw no smoke, no spark, no problem. I have 120 VAC in and the fuse is not blown. I ordered the service manual but its not very helpful to me as, although I have done many board repairs, I am no TV tech. Is there a saftey switch or reset I may be missing? Any help would be appreciated.
  • Panasonic Master
  • 5,138 Answers
Have you CK hori output Transistor and a1200pf 2kv capacitor small blue cap feeds off of hori output?
Posted on Feb 28, 2009
Initial hdtv 262
If this is a projection TV, as it seems to be one in the FIXYA category, you are correct. The power supply is good. The first thing to inspect will be the convergence IC or ICS. These are located on the signal board, mounted on one or two large heat sinks(this board will RF and rca connections attached to it). Check the solder on these pins. You may as well replace the IC or ICs and any low ohm one or two watt resistors (resistors may be 1 to 10 ohms in value). This would be my first concern if I had this TV in my possesion! Thanks for asking.
May 25, 2013 | Televison & Video
2.2 ohm resistor blowing after convergence repair
It might be the issue on the board. I would recommend you to show it to a repairman
Sep 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Element tv
Once again, the power supply is good. The problem is in the signal board. The signal board has the RF and rca connections attached to it. Find the STK XXX-XXX IC or Ics (some have one, others have two). Replace these ICs and check the 1 or 2 watt low ohm resistors (1 to 10 ohms value) and replace as necessary! Wish this TV was in my possession! Thanks for asking.
Can you tell me where the 2 Convergence IC's and the 12, 6.8 ohm 1 watt resistors are located in the Magnovox 51MP329H TV
When you remove the rear cover you will see the large green board on the left side. Note the two large aluminum heatsinks with the fins? The 2 Convergence Ics STK392-120 are attached to that heat sink the 12 6.8 ohm resistors are at board location 3149-3160 they are all the 6.8 ohm 1watt metal film resistor located near the Heat sink which has the two ICs.
Aug 25, 2011 | Philips Magnavox 51MP392H Rear Projection...
I need to identify the parameters (rating) of a resistor for a Panasonic PT53WX53G projector big screen tv. It got hot so I can not see the color codes on it. This resistor glows red when TV is turned...
The resistor you see is a 2.2 ohm 2 watt resistor and is part of the convergence circuitry. I would replace R7011. 7012, 7013, 7014, 7015 & 7016 (all the same value) and the 2 STK392-110 Convergence ICs. This should fix your problem. You can find kits on-line for around $45 with the IC's and resistors together.
Nov 26, 2008 | Panasonic PT-53WX53 53" Rear Projection...
SAMSUNG HCM4215W Rear Projection HDTV shuts down
Low ohm resistors are open or poor solder connections on the bottom of a convergence IC.
You need to look at resistors in good light with magnifying glass. Bad ones may show as discolored or burnt.
The repair needs someone that has the schematic for the convergence cct, and can replace the burnt resistors or replace the whole convergence board.
http://calgaryconvergencerepair.weebly.com/index.html
If you are near Calgary, call me, if not, find someone that has done it before, preferably many times.
easyab
Aug 12, 2008 | Samsung HCM4216W 42" Rear Projection...
Problem with Samsung TV
SAMSUNG Convergence Problem
It looks like blue convergence. Look at menu, select convergence and see if blue top is bent down on convergence adjust screen. Probably won’t adjust.
Some Samsungs have convergence IC’s on a separate convergence board in the back of the TV. Others have the IC’s mounted on the main deflection board. Either way the board has to be removed to get at the dud IC’s and associated burnt resistors.
You remove the appropriate board, determine if any resistors are burnt or damaged, replace any burnt or out of tolerance resistors, replace 1 or 2 IC's and re-install the board.
Now you have to adjust it to look like new.
If the unit has not been misadjusted and everything is OK now, running the auto focus may put the picture back to it’s previous stunning quality, as it was before IC failed.
If after self or autofocus it is still misadjusted noticeably, try the customer convergence adjustments. Operators’ manuals are available on web through searching.
If convergence can not be adjusted properly, you messed up chip install or resistors may be wrong value or open; or it needs major adjustment.
If you live around Calgary, Alberta try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
easyab
Jun 06, 2008 | Samsung HCN4226W 42" Rear Projection...
Sony 7 blinks
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
also found this
CHASSIS: AX1/AX1X/RA6/RA6A
MODEL: KDP51WS550, KDP57WS550, KDP65WS550, KP46WT500, KP46WT510, KP46WT520, KP51WS500, KP51WS510, KP57WS500, KP57WS510, KP57WS520, KP65WS500, KP65WS510
SUBJECT: Picture gets bright then shuts down. After repairs tech noticed a mark was created on all 3 CRT's.
CAUSE: Found Video Output was defective causing the failure of the 200v line. 200 volt line has two fuse resistors R7301 (10 ohm 1/4w) on the CB Board. R8225 (1 ohm 1/2w) on the D board. R8208 (0.47 ohm 1/2w) also on the D Board. All three resistors are in series. One or all 3 could be open. After replacing 2 resistors and Video Output IC set returned to normal operation. CRTs will need to be changed due to phosphor damage. On Models KDP-51WS550, KDP-57WS550, KDP-65WS550 CB Board resistor is R9335 10 ohm 1/4w. D Board resistor is R6509. NOTE: This resistor may be a jump wire according to the schematic. Models: KP-51WS520, KP-57WS520 These models have a fuse resistor on all 3 CRT Boards. CB R9335 10 ohm 1/4w CR R9110 10 ohm 1/4w CG R9211 10 ohm 1/4w On the D Board R6509 is a jumper wire according to the schematic.
Dec 11, 2007 | Sony KP-65WS500 65" Rear Projection...
36XBR400 D board backside capacitor blues
What is the designation (the letters/numbers printed on the board right next to the part) of the part? If it is a cpacaitor then it is cesignated Cxxx, but I have a feeling you are looking at a VDR, or voltage dependant resistor that Sony loves using in their power supplies. A VDR will test completely open on an ohm meter and open on a cpaacitance meter, which means it is good. A VDR that shows resistance on an ohm meter is bad and will probably have a burned resistor (typically 10 ohms) next to it. A wise tech would NOT replace a VDR that measures open!
Jul 03, 2007 | Sony KV-36XBR400 36" TV
Panasonic PT-53WX42 53" Rear Projection Television Logo
66 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
