Question about Toshiba TEC B-472 Thermal Label Printer
Error code XS; I, 0001, 0002C2 - Toshiba TEC B-472 Thermal Label Printer
APC XS 1300 getting A04 error code. Pulled battery and reinserted plugged unit back in and it seems to be working fine now. But for how long?
Good that you got it working. How old is it? Warranty? What does the error code mean? If it is a charging error, the charging system may have a problem. Talk to customer service or email. They like to know how their products are doing. I would guess there is a battery charge level meter via their software and a USB cable connection? If so, keep watching It should give you early warning of battery failure. Or better yet, create your own "controlled" power failure and see how long the battery supports system power. Otherwise, take the battery to battery store. They can test it for you and tell you condition status.
Feb 28, 2015 | APC Back-UPS XS 1300 VA Tower UPS
Tip
Canon Rebel XS Firmware Update MAC Models: Canon EOS Rebel XS / Canon EOS 1000D...
Solves: BUSY Error & Error 99
Doesyour Canon EOS Rebel XS / Canon EOS 1000D suffer from either of thefollowing error messages that prevent it from normal operation?
  1. Some cameras may exhibit a phenomenon in which theLCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. Themessage, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears onthe camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from theactual language setting.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems.
To download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
__________________________
Follow this link to download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
Follow this link to download a pdf version of the firmware installation instruction guide.
Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
on Apr 15, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Tip
Canon Rebel XS Firmware Update WIN Models: Canon EOS Rebel XS / Canon EOS 1000D...
Does your Canon EOS Rebel XS / Canon EOS 1000D suffer from either of the following error messages that prevent it from normal operation?
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
To download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
Error codes xs;I,0001
syntax error due to your print command
{XS;I,0001,002C4100'} and not xs;I.....
Jun 10, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Have a canon rebel xs showing error 99 code Have tried cleaning contacts with eraser ... did not fix Tried sensor cleaning Formatted cf card a bunch of times Removing battery and reinserting helps...
Err99 is a catchall error code, and as the blog post you linked to states, it can be one of many problems.
Have you tried cleaning the contacts? Taking out BOTH batteries? (There's a button cell as well as the main battery.)
Finally, have you got the latest firmware version? The XS is currently at version 1.0.5, which was released in April of this year. You can download it here.
Also, could check this link: 50mm-lens-contact-points/
Hope helps.
May 10, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
We've a problem with our TEC printer B-SX55. Sending a job via parallel interface only results in an error message showing up: XS;I,0001,0012C5 Can anyone tell me what to do to get it up and running...
This type of error message usually means a command error has been found in a command received by the printer. 16 bytes of the command error, hence the XS;I,0001,0012C5 message. It starts from the command code, XS.
I am not sure of all the command codes but I would suggest starting by re-installing the printer driver.
Dec 17, 2010 | Toshiba B-SX5T Printer
Error 99 ?
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 14, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Camera is locked with continous busy error, will not download or take pictures
I hope that helps.
Oct 26, 2009 | Canon EOS Rebel XS 35mm SLR Camera
How can I solve an error 99 problem in my Canon Rebel xs
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Error code
Yes, Canon DSLRs are very sensitive to some NON-Canon lenses.
If firmware inside the camera detects foreign lens, it locks-up the camera.
Basically, Canon wants you to buy only Canon lenses.
Apr 23, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Toshiba TEC B-472 Thermal Label Printer Logo
29 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
