Question about Sigma Accessories fitness - training Rc 1209
Sigma rc 1209 cant sync - Sigma Accessories fitness - training Rc 1209
Cant program olevia rc-ltl remote control to sony vcr
This remote control cannot be set in sync; with Sony VCR, as it does not have a setup code.
Mar 30, 2013 | Olevia RC-LTL Remote Control
Tip
RC looper and DR880 syncing.
RC-50 & DR-880 Setup
Rather than using the RC-50 to change patches on the DR-880, I have connected an FS-6 footswitch to both the RC-50 & DR-880. This gives me control of both units, I can select up & down through the patches easily.
Use a dual TRS connector and 2 stereo "y" cables connected to ports 1,2 & 3.4 on both units.
Once connected, you will need to assign the control function for each control port. I assigned Patch Decrease to CLT 1,2 & Patch Increase to CLT 3,4 on both units.
I then connected a MIDI cable from the RC--u control of start/stop & tempo via the RC-50 footswitches.
on Feb 25, 2015 | Roland Boss RC50 Loop station (with )
Syncing with Sigma BC1009
Had this same problem and nothing worked after trying everything I could think of. Speedometer would never display a blinking 0 (just stagnant). Turned out the computer mount on the handle bar was turned around backwards. The sigma letters go towards the front of the bike. Placed the device in the mount, the 0 started blinking and sync'd up with sensor. Finally works!
Sep 13, 2012 | Sigma Sport BC 1009 STS Wireless Computer
I cant use my nokia 1209, it requires security code, i tried 12345, but it doesn't open IMEI-358273034109638
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 25, 2012 | Nokia 1209 Cell Phone
Rc sunfire. remote works the steering but not the throttle.
try sync it to level 4 on it will turn green on full throtal I did it then I had to do it again because I charged the battery and had to sync it again try this when I did not do it second time it just stop tell me if that is the problem not a good discharge battery for 3000ninh 8.4
Sep 04, 2011 | Exceed-RC Exceed RC Brushless Pro SunFire
I have a sigma 170.500 but cant find a manul for it can you help me diane cronin
your best bet is to go to the manufactures website. Here is the manuals for all of the cameras they make. Find yours and download
http://www.sigma-photo.co.jp/english/support/catalogue/use.htm
May 03, 2011 | Sigma Cameras
Im trying to connect two rc-50 via midi! I want one of the them to act as a master and the other one as a slave. The goal is to have both machines working independently but have all loops on each rc-50 to...
While you can probably get the functions sent by MIDI to transfer to the other unit, syncing PROBABLY isn't going to work very well because there is a lag to form the MIDI sync clock (serial data) and then receive it, decode it and do something with it.The transmit time is about 1/3000 of a second and receiving is at least that much time. On rhythm things I have found the ear can hear 1/1000 of a second easily. If one could set the machines to use an EXTERNAL sync clock and drive the SAME clock to both units, you might be able to sync them together time wise as they would see the sync at identical times.
Apr 14, 2011 | Boss Rc 50
Help unlock my 1209
i bought cellphone. i couldn`t my cellphon security number. cellphone medel Number is nokia 1209. what have phone first sicurity nnumber? how can find security number?
May 08, 2009 | Nokia 1209 Cell Phone
Sigma Accessories fitness - training Rc 1209 Logo
87 people viewed this question
Top Sigma Computers & Internet Experts
David Payne
David Payne
Are you a Sigma Computer and Internet Expert? Answer questions, earn points and help others
