Question about Sony CDX-C7000X CD Player
Won`t power up - Sony CDX-C7000X CD Player
    Scholar:
  • 116 Answers
Make sure tht BOTH th red AND yellow wires are getting power. Yellow is 12V constant, red is 12V switched, oh and don't forget the black wire needs a ground! If STILL no pwer up, check fuses in line with the wires, if good, tis next step has saved me several times. Power up the red and yellow wires, then hook up the blue/white wire. YES I know that tha is a remoteout wire for amps, but I tell you I have freaked out several of my employees showing them my trick.
Oh yeah, and it THAT doesn't work, then you can either repair it, or use it at a sounnd off when they hve radio tosses LOL!
Take care,
l;arry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
Why won 't computer communicate with code checker
Check the cigarette lighter fuse. This is what powers the DLC. If the fuse is good, check and see if the lighter works. If not, you have a bad wire. Code readers have to have power from the car. Most scanners have there own power and will read the computer, unless the data wire is bad or the computer is bad.
Mar 28, 2015 | 1995 Buick LeSabre
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a 1984 chevy truck 350. new battery, Forget start! It won't turn on ! I have power to dist. new ignition mod. and power to the steering col.
forget start it won`t turn on but you have power to distributor i don`t under stand what you have yet the engine won`t crank over?? or it cranks but no start let me know thank you
Sep 16, 2011 | 2004 Pontiac Grand Am
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Sony CDX-C7000X CD Player Logo
67 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
