Question about Denon AVR-2802
Also problem with Denon AVR-2802
I also have a problem with the Denon AVR-2802. Worked fine in 5 years. This spring some of the channels started to drop out, and I returned it for repair. The terminals was soldered by the repairshop and it seemed to work fine after this repair. Now no sound is produced from the speakers (both in playback with tuner, dvd, cd-player and in the channel level configuration). If I just turn the reciever on in very high volume (-05) i could hear a very weak output in the speakers, almost as if the amplifier doesent add any amplification to the signal. Odd that so many on the web has this excact problems with the AVR-2802 after 4-5 years.
  • Andreas Hagen Jul 22, 2007
    PS! If I try to change any settings after turning the reciever on, the weak sound dissappears and I have to turn it off and on againg to produce any sound.
    Problem Solver:
  • 5 Answers
If DIGITAL sign on the display blink, it mean the DSP board is defective. probably the DSP itself
Posted on Aug 29, 2008
  • Anonymous Sep 11, 2008
    If DIGITAL sign on the display blink, it mean the DSP board is defective. Change IC,
    AT49LV002-70TC
    (IC
    817 ) at DSP board (Denon P/N
    262 3010
    006).
SOURCE:
Denon AVR-2802 Optical Issue
If you look at page 16 of the user manual it tells you how to assign the devices to the optical connections. Once this is done it should work.
If you don't have the manual just type "denon avr 2802 manual" into Google and it will show a free PDF file of it. On my search it came up first!
Feb 09, 2018 | Denon AVR-2802
its just the amplifier problem
Apr 02, 2008 | Denon AVR-2802
I want to know if there is anyway to play music from my ipod touch 2cnd generation with my Denon AVR 2802 Home Theater System.
mini 3.5mm to rca adapter is very simple adapter available most anywhere its headphone to red-white and works very well and only cost 5$ or so ok:)
Jun 03, 2011 | Denon AVR-2802
I have denon avr-2802.. suddenly no sounds will come out but the power ok.. help me pls..
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-2802-Receivers-manual/id/363bh830/t/2/
Is it silent for ALL inputs including the Test Tones?
Page 33
Function incorrect, Muting, Tape or EXT Input on when it shouldn
Feb 19, 2011 | Denon AVR-2802
I have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Apr 13, 2010 | Denon AVR-2802
Denon AVR-3300 component channel switch burnout?
hi there, i don't have a solution unfortuantely, but i may have the same problem. I have a denon 2802 av receiver, i bought it second hand and I can't seem to get the component video in / out working. Are you supposed to just plug it in and it works? Because I can't find any buttons or settings to select component in / out as my input / output sources?
Nov 12, 2009 | Denon AVR-3300 Receiver
Denon 2802 amp
Dear Armani,
You cannot put de leads from an MP3 player or your TV into the pre-amplified connection of your Denon,
the phono "stage" is a low input stage, your input from MP3, TV, CD, DVD oscasetteplayer is high output (a 5 to 10 times stronger signal)
Try every other stage like tape 1 or 2, this will work just fine,
succes
Apr 30, 2009 | Denon AVR-2802
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
Denon 2902 No Sound
REPLACE MUTING TRANSISTORS IN DSP PANEL
Sep 04, 2007 | Denon AVR-2802
Denon AVR-2802 Logo
1,435 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
