Bissell Proheat 9200
SOURCE: manual
Hi vanessaking. Here is a copy of the user's manual for it; http://www.bissell.com/images/UserGuides/9200-605web.pdf You might also wanna take a loot at this support section for this specific model for any other concern; http://www.bissell.com/Products/product.asp?catalog%5Fname=Bissell&category%5Fname=&product%5Fid=ProHeat+2X Hope that helps ! :) cheebster.
SOURCE: I have bissell proheat 2x 9200 no water or
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
SOURCE: bissell proheat 2x carpet cleaner 9200 How do i
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
teyet
