How can I set up the ADF to copy on dell printer 3115?
I'm trying to make copies thru the Automated feeder or ADF and it's not responding.
Can you please lead me to set up the ADF to copy?
  • 1 more comment
  • Rick Kasper May 11, 2010
    What make and model ?
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the make and model of the copier?
  • Joseph Micallef May 11, 2010
    Is it showing any errors?
  • 3 Answers
It would help to know what kind of machine this is. But check to make sure the cable from the ADF is plugged into the back of the copier. If it is not. Turn off the machine, unplug it from the wall, then plug the ADF into the machine. After that is complete plug the machine back in and power up.
Posted on Feb 04, 2009
Hp laserjet 4345 mfp cannot photocopy anything because the startup button has a red light
Hi Bridgette.
The red light on the startup-button indicates that the machine is not ready for a photocopy. Usally there is something stuck in automated document feeder (ADF). Take a close look and see if can see something in the paperpath. If no luck, try pushing a A4 sheet manually through the ADF and see if something comes out with the sheet. Usally there is a small piece of paper, a paper clip or a staple stuck in the ADF. If nothing found in the ADF, the Scanner Controller Board is probably broke, and needs to be replaced. Good luck.
Dec 31, 2013 | HP LaserJet 4730mfp All-In-One Printer
Copying 8.5x8.5 original thru document feeder and it doesnt aal print
Most copier has an APS (Auto Paper Selection) as default, 8.5 x8.5 is a square original, I would suggest you manually select the paper tray (e.g. Letter) first (this will temporary disable the APS for this session), then lay it down on the original glass, or ADF (Auto Document Feeder).
If you do not disable APS, you will have paper jamming problem, you do not have 8.5 x8.5 is th paper tray, of course, you may try it feed from the by-pass tray, set the the paper size to 8.5 x8.5 or special size ....... Each manufacturer has a different name for the same function (terminology).
Nov 12, 2013 | Canon for IMAGERUNNER C2020 C2050 C2058...
What does the ADF input tray do? and how do i use it ?
Place the documents in the tray, face up.
If you want to copy them, then press copy.
If you want to scan them, then press scan or you may have to open the Dell All-In-One Center to scan the documents to your computer.
ADF stands for Automatic Document Feeder.
The scanner bulb stays stationary and the paper passes over the light reading what is on the document.
Jan 10, 2011 | Dell 946 All-In-One InkJet Printer
The paper will not feed to fax or copy on the top loader.
If your Dell 1815DN is jamming at Document Feeder (ADF assembly) the display may read Document Jam. You should replace the ADF Seperation Pad (Part# D1815-Z3) and the ADF Pickup Assembly (Part# D1815-Z4). Here is a video that shows you how. has these parts and ships same day.
Jun 20, 2010 | Dell 1815dn All-In-One Laser Printer
My copy machine is D 861 digita.when i make a copy
If you're using the automatic document feeder (ADF) to scan the document, make sure the ADF scanner area is very clean. This is the area of the platen glass to the right side. Also make sure that you don't have reduction set on the copy size.
Jan 18, 2010 | Canon ImageClass D861 Printer
Brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
Adf pulls 2- or more pages in feeder.
open the ADF and clean the rollers and wooden cork pad and unplug the machine and press and hold the ON button for 1 min and release the button and plug it bak and it should resolve ur issue........
Regards raj_p5983
Jan 21, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Line in copies that go thru feeder
Over time the automatic document feeder (ADF) will get dirty, occasionally causing vertical black streaks or lines in scans and copies .
Manual cleaning of the ADF might be necessary. Follow the procedure below to manually clean the ADF .
You will need the following materials:
  • Soft lint-free cloths
  • Glass cleaner
if you look carefully on the left side of ADF ( top feeder ) there is an assembly which u can lift , there wud be a set of rollers if u lift that part there would be a glass strip . u are suppose to clean that strip .
While holding up the inside of the ADF, clean the glass in the location of the vertical streak with one of the cotton swabs. Try cleaning the glass first with a dry cotton swab. If that does not correct the problem, then moisten the swab with glass cleaner .
If the vertical lines or streaks still appear, go through the above cleaning process again, this time cleaning the entire surface of the ADF scanner glass.
and after this try the following steps as well .
CAUTION: Use only glass cleaner. Avoid abrasives, acetone, benzene, and carbon tetrachloride, all of which can damage the scanner glass.
Apr 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Will not copy
If the paper isn't feeding in the ADF (automatic document feeder - upper paper feeder) then the ADF roller assembly will need to be replaced. Try a copy on the flat glass area. If it work, then it's the ADF, If not then the upper scanner assembly with have to be replaced.
Apr 28, 2007 | Canon imageCLASS D880 All-In-One Laser...
81 people viewed this question
