Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
I want to know which way the piston and ring goes on a 1999 johnsonred 2065 chainsaw
    Sergeant:
  • 322 Answers
The piston ring opening should have a spot on the piston with a little nub to align it. If it doesn't then just make sure the ring openings do not line up together. As for putting the piston in, there should be a mark on the top that will go toward the exhaust side
Posted on Jan 24, 2013
2 Suggested Answers
  • 2239 Answers
SOURCE: How hard is it to change piston, ring, and
It is a full strip down, the cylinder makes up part of the crankcase and sandwiches the crank and main bearings, it is not a job for an amatuer, i can try to go through it if you wish to carry on with it.
Posted on Jul 27, 2011
I'm replacing piston ring on husqvarna model 240 chainsaw. I would like to know if bevel edge on ring ends face up or down on piston
Most 2 cycles have a pin in the piston groove that keeps the ring from traveling. The pin location (upper groove, lower groove position) will give you the indication. Most 2 cycle rings have an L shaped cut in the very end that mates with the pin in the groove. Otherwise the piston/ring assembly will not fit into the cylinder.
Mar 26, 2017 | Husqvarna Garden
How to un-sieze a chainsaw.
basically you need to strip it down, remove the cylinder off the piston, then remove the piston itself. Replace both. Hot seizes tend to damage more than just the rings, they score both piston and barrel. Its not a small job so if in doubt, take it to someone who knows what they're doing.
Nov 09, 2015 | Garden
How do i replace piston rings stihl ms170 chain saw
Part 4: Stihl chainsaw piston and cylinder replace / repair ...
? 13:54
https://www.youtube.com/watch?v=jCbMCkGqCIQ
Dec 15, 2011 - Uploaded by Andy Reynolds
Refitting the cylinder to the rebuilt crankcase on a Stihl 026 chainsaw. ... Part 4: Stihl chainsaw piston and cylinder replace / repair. .... Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings - Duration: 15:10.
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti ...
? 15:10
www.youtube.com/watch?v=n9RbtjNc-nc
Dec 16, 2011 - Uploaded by Andy Reynolds
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings ... Part 4: Stihl chainsaw piston and cylinder replace/ repair.
Oct 29, 2015 | Stihl MS171 12" Chainsaw
Where to find piston ring?
Is it just the piston ring? If so you may be able to substitute a ring from some other manufacturer. If you do go this route then be aware that you may have to set the end gap on the piston ring.
Jul 16, 2014 | Garden
Inslall piston ring
Never twist the piston ring. Pull it straight apart. This will insure the ring will seat properly.
Mar 31, 2014 | Husqvarna Husky 345 345 Chainsaw W/ 16"...
Repair piston rings
Remove the cylinder to expose the piston and rings,the rings should be lose around the piston, they should have a break in them so they can be removed and squeezed in to fit back into the cylinder
Aug 03, 2013 | Stihl Garden
I want to know which way the piston and ring goes on a 2065 johnsonred chainsaw
The piston crown will have an arrow on it if you clean the carbon off, the arrow always goes towards the exhaust port which puts the ring peg at the inlet.
Jan 23, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
I am looking for a workshop manual for an 029I am want to fit new rings to it and check out the oil pump. It seems to be not pumping enough oil.
The adjusting screw is underneath the saw. You shouldn't monkey with the rings unless you know what you're doing and if you know enough to change rings, then why would you need the manual? Are you looking for part numbers for the rings? The upper ring is 1118 034 3001 and the lower one is 1113 034 3006. DO NOT GET THEM MIXED UP! You will destroy the engine REAL quick.
Jul 24, 2011 | Stihl Chainsaw Piston Assembly (44mm)
How do i remove piston pin from 375 poulan pro
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I suggest you look around the above site. Someone here has been where you are. You can join for free and they are a very helpful group of folk.
Apr 21, 2010 | Poulan Pro Chain Saw 46cc 20"
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
