Question about Xerox Phaser 8400 Laser Printer
Need help with error code 08,055.44:10509
What is it and how can I fix it?
  • Xerox Master
  • 1,314 Answers
The media path drive module has stalled while engaging the headtilt.
1. Check for an obstruction in the wiper assy drive.
2. Check for a broken wiper drive belt or gear.
3. Verify the head lock mechanism on the right end of the
exit module assembly is functioning properly.
4. Run the Head Maintenance Clutch test, replace the
wiper drive clutch if the test fails.
5. Run the Wiper Drive test. Replace the exit assembly if
the test fails.
I have the service manual available should you need it. Thanks and please take a moment to rate as fixya.
Posted on Mar 10, 2009
How do i fix error code 42 on my cellphone? Help! Ive tried everything!
How to Repair Error Code 42 ' Windows Error Support - Error Tools
  1. Cached
  2. Similar
Code 42 Error is referred to as a Device Manager Error code. Before we explain what this code indicates, it is important to understand what 'Device Manager' is and its functions. Device Manager is basically a Windows tool that helps manage devices attached to the system such as the Printer, Scanner and the USB Device.
Error codes in Device Manager in Windows - Microsoft Support
  1. Cached
Lists the error codes that may be reported by Device Manager and the possible resolutions in Windows. ... Manager. If you are getting an error code that isn't listed here, you can contact the hardware device vendor's technical support or Microsoft Support for help. ..... Code 42 "Windows cannot load the device driver... (Code ...
ERROR CODE 42 - Boost Mobile Community
  1. Cached
Sep 3, 2017 - 1 post Help! I can't send or receive text messages! It keeps saying: Error code 42 I can't call or receive calls either and I know that my bill isn't due.
Instructions To Fix Windows Error Code 42 -
  1. Cached
  2. Similar
About the Error. The Windows error code 42 indicates the fact that the operating system has detected a duplicate device. This is usually caused by a sub-process that the system accidentally named incorrectly. Windows code 42 - Read what really helps. Though Windows error code can sound quite intimidating, fixing the ...
Dec 14, 2017 | Cell Phones
How can i fix marketplace error code D000F001 from my lumia 610?
Oct 15, 2017 | Cell Phones
Went to open Quickbooks pro 2008 and received an error code of 80029c4a. It also said there was an error loading type library/DLL. Any solutions
Steps to fix QuickBooks Error Code 80029c4a Call 1-888-909-0535
quickbooks-error-code-80029c4a-fk2nwqyksotv4h0olihktnx1-5-0.jpg If you want to fix QuickBooks Error Code 80029c4a Call 1-888-909-0535 QuickBooks Error Support Phone Number for help or follow steps to fix QuickBooks Error 80029c4a. Visit our blog:
Sep 24, 2017 | Computers & Internet
I got an error code E000007-9901 for Canon Irc 4580, how do i fix it
The Nearest error code seems to suggest pressure belt/fixing belt trouble
Feb 18, 2015 | Canon iRC4580i
Sc (28112) error
I have a ricoh SG 3110 DN error code 28112. Can I fix this?
Dec 07, 2013 | Ricoh Aficio Sg 3110Dnw 29Ppm
Brother MFC-8440 Machine Error Code 7A - tried to print something and machine stopped, beeped and gave me this code. No resolution from Brother other than to have a tech come look at it. Any insight...
Hello thanks for using FixYa
Error code 7A occurs in different forms and they are linked directly to errors caused due to calculations as detected by GPU, however, it is still doubtful what exactly cause these GPU errors in hardware and the errors in WU. Keep in mind that this error code could also suggest that the main PCB is broken.
For the error code 7A to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition. If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor. In this case, make sure that there is no mechanical load present on the main board. While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Feb 14, 2011 | Brother MFC-8440 All-In-One Laser Printer
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
CANON IR5000 ERROR CODE E000002-00000
Mar 27, 2009 | Canon imageRUNNER 5000 Copier
Xerox Phaser 8400 Laser Printer Logo
221 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
