Question about Hotpoint Belt Drum Drive for VTD00, VTD20, VTD60 Tumble Dryers
F12 fault on Hotpoint VTD 60 tumble dryer
Clean filter and F12 fault showing on Hotpoint VTD60 Tumble Dryer, does anyone know how to reset.
Malcg
  • 32 Answers
SOURCE: tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Posted on Apr 13, 2008
barkencoa
  • 3463 Answers
SOURCE: display saying f-10
Heater or thermostat faulty, probably thermostat, there are 2 of them, replace both.
Posted on Nov 18, 2008
  • 100 Answers
SOURCE: not drying
the steam gets condensed back to water and pumped away so sometimes draining problems cause poor drying. is the machine plumbed in according to handbook?
also your dryer filter may be blocked but this is not accesable without the dryer box being stripped down.
Posted on Feb 06, 2009
amgm
  • 32 Answers
SOURCE: Hotpoint Aquarius VTD 00 Tumble dryer no heat
Hi, it sounds like the reset stat gone on your vented drier. Remove the back cover, where the element is, and you should find two stats, one with a green spot. That's your reset stat. If you have a multimeter, turn it to buzzer and check the stat by touching the connections with the meter leads. If there's no buzzing, it's the reset stat. also check if the dark side of the stat is pushed inside. Remove the stat and hold it about 20inches from the floor. Drop it on the floor and the dark side will become flat. Repeat as many times as necessary. GUARANTEED TO WORK. Put everything back and that's it.
Cheers
Posted on Feb 15, 2009
  • 160 Answers
SOURCE: We have a washer dryer hotpoint bwd129. Can you
a washer dryer has a different approach to cleaning fluff. It has an internal flushing system.. only do routine check on pump filter.
Posted on Oct 19, 2009
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
Tip
Common faults on a hotpoint tdc32
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuitboards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also bethe fault.
For Free Video help on yourHotpoint TDC32 Tumble Dryer USE THIS LINK
on Jan 17, 2010 | Hotpoint TDC32 Electric Dryer
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Dryer making noises whilst in use.
all vtd range have bearing problems
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Oct 15, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hotpoint vtd00p thermostat
It could be the thermostat has burnt out or possibly the start capacitor
needs replacing
Aug 30, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Need to replace belt on vtd20g hotpoint tumble dryer
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
May 10, 2012 | Dryers
Need to take apart a hotpoint tumble dryer vtd00t
Sep 21, 2010 | Dryers
Hello I have a hotpoint tcp 1p tumble dryer
this sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail (meaning open circuit)
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Dec 20, 2009 | Hotpoint Dryers
Display saying f-10
Nov 17, 2008 | Hotpoint Dryers
Hotpoint Belt Drum Drive for VTD00, VTD20, VTD60 Tumble Dryers Logo
41 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
