Question about E-Mu 1820M Sound Card
Is my e-mu 1820 work with my accer cpu - E-Mu 1820M Sound Card
    New Friend:
    Problem Solver:
  • 6 Answers
Simple answer: Yes, provided that you have a free PCI slot in your Acer. The E-MU 1010 PCI controller board is the only controller that will work with an 1820. The PCIe version will not work an one or both may be damaged if you try.
Do not expect to get anything close to good latency from an old computer. If your Acer is a P4 or an equivalent AMD or newer you should be fine.
Posted on Nov 16, 2014
I having pcs motherboard, and also lg driver, but the edi pin and also motherboard edi pin is not suitable . . . what about the solution
If I'm interpreting what you are saying correctly it sounds like you are either trying to use the on board network connector on your mother board to connect to a Audio Dock, or you are using the wrong kind of Audio dock together with your PCI or PCIe E-MU card.
Scenario 1: You'll most likely fry the network connector and the Audio dock or if you are really lucky only one of them. Fingers crossed that it's the cheaper of the two that goes.
Scenario 2: The 1616/1616m will only work with the PCIe version of the controller card from E-MU. The 1820/1820m will only work with the PCI version of the controller board.
Again, if you are lucky your hardware is still functional, but I wouldn't bet on it. Combining the wrong controller with the wrong Dock will most likely smell a bit funny after a while.
The PCI version of the controller board provides power to the whole 1820 and considering how hot the docks can get you can bet that it's quite a lot of current that is provided.
I've tried to figure out the pinout of the EDI-connector and there's a 48VDC going into the dock's onboard PWM-regulator. This is apparently generated from a floppy-power connector providing an additional source of 12VDC to the step-up PWM on the controller board.
Jan 12, 2012 | E-Mu EDI Cable Sound Card
Ang problema ng cpu ko ay may power cya tumatakbo din ang processor.ngunit walang lumalabas sa monitor.
check lahat ng cable lalo na ung papunta sa monitor,tapos try mu rin sa ibang computer ung monitor mu, kung ok naman, open mu ang cover ng CPU dahandahan mung tanggalin ang memory,linisin mu ng eraser ng maingat ung kulay gold side ng memory.. then try, pag wala parin, try mung lagyan ng ibang ayos na memory, kung may tunog naman, 1 Long 2 ShortVideo Card Error - Either re-seat or replace video card,Repeating beepsMemory Error - Memory is either damaged or badly seated.
Aug 12, 2011 | Computers & Internet
Can the EMU 1212m work with the EMU 1820m Audiodock?
If I remember correctly you'll have to choose between the 1212-board and the 1820m-dock. The internal 1212-board is not needed if you have an 1820 and, as the line inputs/outputs on the 1212 appears as DockA/B and line 1 R/L on the 1820.
Dec 18, 2010 | E-Mu EDI Cable Sound Card
I have a kyocera km 1820 copier at work and cannot figure out how to navigate it to make 2-sided copies???
The Kyocera KM-1820 does not have an automatic 2-sided option. This is why it cannot be found in the settings.
May 20, 2010 | Kyocera Copystar CS-1820 Black and White...
I need sound card driver for dell 1015 for window xp
you can download the drivers from dell website or from here. Before that download Microsoft Universal Audio Architecture from here and install it.
Everything should work fine after that.
I hope this is helpful to you.
Nov 07, 2009 | E-Mu EMU 1820 24 Bit 192K Interface with 2...
I can't get the software/drivers to download to my PC (Dell GX280 w/3gb ram XPpro). I'm trying to use the bundle that came with the purchase of my 1616m and I get a message that says it doesn't see any emu...
Try removing the device driver in Hardware manager, then 'refresh' to tell it to look for a new driver. Keep the CD in the drive, and have windows search it for the driver.
Oct 24, 2009 | E-Mu EMU 1820 24 Bit 192K Interface with 2...
Emachine compatable with e-mu 1820?
If you have a PC that is less than 2 Years old, it should work with the e-mu 1820.
Here are the specs needed:
Minimum System Requirements:
  • Genuine Intel Pentium III or AMD K6 class processor
  • or higher operating at 500MHz or faster
  • Intel, AMD or 100% compatible motherboard & chipset
  • 128MB System RAM
  • 500MB of free hard disk space for full installation
  • Windows 2000 SP 4, Windows XP SP 1 or greater
  • PCI 2.1 compliant slot for E-MU 1010 PCI card
  • CD-ROM or DVD-ROM drive required for software installation
  • XVGA Video (1024 X 768)
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Mar 16, 2009 | E-Machines eMachines Desktop PC
    E-Mu 1820M Sound Card Logo
    189 people viewed this question
    Top E-Mu Computers & Internet Experts
    David
    David
    Steve
    Are you an E-Mu Computer and Internet Expert? Answer questions, earn points and help others
