Question about Samsung Prostar 816 Display Phone
We can't reprogram the phone afeter the power goes out.
Hold time and which phones rings. The system did not come with a tech manual.
    President:
  • 860 Answers
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
hope that helps
Posted on Feb 13, 2009
I have a panasonic A-616 after power failure the system restored but none of the phones will ring just the line lights flash
Either the software took a spike and jumbled up programming or the memory capacitor no longer functions.
Call a tech/vendor to reprogram and advise on future for power fails.
Jul 19, 2012 | Panasonic Lands Phones
My store had a huge power outage where the lines were sparking. Anyway since the power has come back on I have no ring & can not dial an extention after i dial a phone number. I have looked in the...
So you're saying you can dial a phone number, but when the voicemail system answers you can't dial an extension number ? If that's the case, that means your phone system reset. Generally that means all phones will have access to only line 1 and 2, and that they'll be ringing on all phones. The date would usually change to Jan. 1st 1980, but caller-ID might override that. All line programming would be set to pulse, which would be the cause of you not being able to dial an extension number a voicemail system answers. It would also mean that when you do dial a phone number it takes a while before you hear it ringing. (Because the phone system is dialing in pulse instead of tone, if you stand next to the phone system you'll probably hear it go)
... Long story short, your entire phone system needs to be reprogrammed. I suggest only doing a partial reprogramming, then unplugging the power for a few minutes and check to see if the programming stuck. If not, the battery in your system also needs to be changed.
May 20, 2011 | Nortel Meridian M7208 Corded Phone
Power outage now you have to select a line manually instead of just picking up phone and it's taking awhile before it starts ringing
What usually happens after a power outage is the system defaults because the backup battery in the memory card is dead. That means 2 lines only on every phone, pulse dialing, and all phones ring. If your system looks like that, it's time to call the Nortel repair tech. He can replace the battery or software module with a new one and reprogram the system.
Carl
Aug 17, 2010 | NorStar M7324 Corded Phone
I use Panasonic Kx-T7730 as a propitiatory telephone. When someone calls from outside, All phones on the network ring. It had to ring only on the proprietary telephone.
The 7730 plugs into a Panasonic phone system. That system (KXTA, KXTD, KXT-something) has programming. Each system has a manual or set of manuals to program system ringing. Comment back or search the internet or your files for that manual and it can be reprogrammed.
Carl
Jul 14, 2010 | Panasonic KX-T7730 Corded Phone
I have a Lucent "Partner Endeavor" communications system from 1999. I had unplugged the system briefly, and now when callers call me, they get a message "Sorry, but we cannot complete your call as...
If you didn't remember to change the batteries in the processor card, you now get to do it and reprogram the entire system :-)
My guess is that the VM card is now defaulted to ring on the first ring.
The recording is a puzzle, but you will probably figure it out once you get the voice mail system and ringing programmed. Here's an Endeavor manual, if you don't have one. http://support.avaya.com/css/P8/documents/100013703
Carl
Mar 24, 2010 | Cell Phones
My v-tech phone will not set to EST. It goes back to Pacific time as soon as the phone rings.
The key is "as soon as the phone rings". Who's ringing it? I had one of those on Packet8. I had to go to their website and get the instructions to change the time offset in the Packet8 ATA. Check with your dial tone provider for a solution. Carl
Jun 16, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
Since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
Jun 15, 2009 | Avaya Lands Phones
Sony Ericsson z750a incoming rings end too quickly.
cancell all call diverts. it may be happening due call diverting.
Jun 04, 2009 | Sony Ericsson K750i Cellular Phone
Voicemail timestamp & "on hold" too long
Yes Music can be played from your system during transfer. Simple connect any radio or cd player to the RCA jack located on your KSU (main box) For setting the time in voicemail log into box 999 with sec code 999997 or just 997 and press 8 for admin features. More guides and ACTUAL manuals can be found here
http://guides.idacomusa.com/
May 18, 2009 | Toshiba DKT-2020 Corded Phone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Lands Phones Logo
176 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
